Old 22-07-2013, 06:07 AM   #1
Mulga
Mulga's Avatar
Default Focus ST engine noise
Purchased a 2013 ST (demo) a few weeks ago and absolutely loving the car.
However, I have noticed that after the engine warms-up there is what sounds like a tapping noise, very similar to pinging. I have checked the noise when the car is idling.
I'm running the car on Optimax 98, but it I sounds more like a tappet noise.
Obviously, I'll take it in to the dealer, just interested if anyone has similar or heard anything around the traps.
Thanks
Mulga is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2013, 06:14 AM   #2
WILDB
WILDB's Avatar
Default Re: Focus ST engine noise
It's the fuel injectors, direct injection motors can be a bit noisy in this regard.
Mine has been the same from day dot, all of the others I've heard have also been the same. It's a hell of a lot noisier with the engine cover off too.
WILDB is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2013, 07:42 AM   #3
Mulga
Mulga's Avatar
Thanks WILDB.......I had a Focus LS-LX (2006) previously, and the engine was much quieter compared with the ST.
I'm loving the ST though and power aside, it's also a great handling car.
Old 22-07-2013, 11:15 AM   #4
gassed250
Mine does it to
sounds like valve train noise to me
GH Sigma EFI 351, 394whp @6500rpm
gassed250 is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2013, 03:20 PM   #5
aratic
aratic's Avatar
This will be because the older Focus is not direct injected.
If you have any doubts about Fords GDi engine being noisey, have a listen to a Golf Gti or R engine.
2013 Ford Focus ST
aratic is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2013, 01:10 PM   #6
phil545
Hot Hatch!
phil545's Avatar
mine is so noisy, not a tapping noise more like a whuring noise, that sounds like a bearing, i think all the ST's have it but mine is just louder as comparing it to my brothers there is a difference. Ford have noted it but said its within acceptable limits or some ****, its really noticable when you are next to another car for the sound to bounce off it. its high pitch, almost like the turbo whistle but not quite
I hate arriving at my destination as then I have to get out of my car!
New Build Thread! http://www.fordforums.com.au/showthread.php?t=11396029
Old BF Falcon Build Thread - http://www.fordforums.com.au/showthread.php?t=11317452
phil545 is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2013, 09:54 PM   #7
Mitch89
Mitch89's Avatar
My dad's 2012 BMW Z4 had the 2-litre DI turbo petrol engine, and it sounded like a tractor idling. It's weird, but normal.
Mitch89 is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2013, 10:34 PM   #8
phil545
Hot Hatch!
phil545's Avatar
Idle is fine in respect to diesel/tractor noise, this is a rather high pitch swuring noise instead
Old 29-07-2013, 07:23 PM   #9
aratic
aratic's Avatar
I have the same sound but its 'normal'. Dropped mine off at the dealer the other morning and when I was at the bus stop I saw another ST drive past and I heard this noise from the other side of a busy road
2013 Ford Focus ST
Old 29-07-2013, 09:26 PM   #10
phil545
Hot Hatch!
phil545's Avatar
Yeah its weird, you can hear it more when you are in the car, i just go my bro to drive my car past me and i couldn't really hear it, just the turbo spool and exhaust. I was told the same thing that its within acceptable limits. Im hoping once i change the oil it will quieten down a bit, was goin to switch at 7.5km but the bottle says to use it after the first manufacture oil change
Old 30-07-2013, 09:11 AM   #11
aratic
aratic's Avatar
Explain?
2013 Ford Focus ST
Old 30-07-2013, 06:13 PM   #12
phil545
Hot Hatch!
phil545's Avatar
Haha whats there to explain? Was going to change the oil at 7500km but the royal purple says its recommended to change it after the first manufacturer change which is 15000km, when that rolls around i might supply them the oil and filter for a reduced price
Old 30-07-2013, 06:51 PM   #13
aratic
aratic's Avatar
I don't see why you cant use it straight away that's all. Having to wait a certain period before changing over to a synthetic oil on a car designed to use synthetic oil does not make sense.
Also you probably won't get a discount off the capped price servicing for supplying the oil, I've already asked
2013 Ford Focus ST
Old 30-07-2013, 07:01 PM   #14
phil545
Hot Hatch!
phil545's Avatar
Yeah i dont really wanna wait either, its the api licensed stuff so i might just go ahead and change it at 7500, i dont want to waste money and have ford change the oil at 15 just to then change it back, hmmmm
Old 30-07-2013, 07:09 PM   #15
pajoda
pajoda's Avatar
If you want your own oil just supply it at a service interval. I bet they will not attempt to enforce some minute level of characteristic that equates to their minimum level of requirement. I bet anything of 5W30 these days will suffice.
2018 Ford Focus RS
pajoda is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2013, 07:45 PM   #16
aratic
aratic's Avatar
That's more or less what my dealers service manager said, any 5w30 is good
2013 Ford Focus ST
Old 17-08-2013, 07:14 PM   #17
RikBiel
From what I have read about these lovely ST's I suspect if you apply sufficient pressure to the accelerator, any unpleasant noises soon disappear.
Oxford white 2020 Mustang GT 5.0 with black shadow pack - 10 speed auto
BIONIC 2006 FPV BF GT-P #15 - 6 speed ZF auto - front and rear Brembos - stock - Unknown rwkw
BIONIC 2005 BA Mk2 XR6 - Mace Engineering CAI and pod filter- polished BBM intake - polished ceramic coated Pacemaker 4490 headers - Magnaflow 3.5" high flow Cat - Full mandrel stainless exh syst - 4speed SSS -BPT Custom tune - 20% UDrive - XR8 Calipers/rotors - FG XR50 rims - 175 rwkw
RikBiel is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2013, 12:42 AM   #18
Copie
Why use RP oil though? It's just overpriced for what it is, for the money you outlay you may as well get mainlube.
Copie is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2013, 10:19 AM   #19
gassed250
so long as it meets WSS M2C-913-C
Recommended focus ST oilshttp://www.opieoils.co.uk/c-1251-wss-m2c-913-c.aspx
Old 18-08-2013, 05:31 PM   #20
aratic
aratic's Avatar
Or WSS M2C946A as the USDM ST's
If in doubt talk to your service manager...
2013 Ford Focus ST
Old 29-03-2014, 10:37 AM   #21
aratic
aratic's Avatar
Seeing as oil was discussed in this thread, thought it might be appropriate to post that Supercheap are now selling Valvoline Synpower FE oil which meets the 913C Ford spec
http://m.supercheapauto.com.au/Produ...menuFrom=60104
2013 Ford Focus ST
Old 29-03-2014, 05:33 PM   #22
Copie
Funny thing about Valvoline, the base oil used in their lubricant range is actually recycled out of a placed called transfield in Sydney, its sent from there to Rutherford where its processed and cleaned then sent upto Brisbane to be refined and have their various additives put in, bottled and sold to the public.
The waste base oil is nasty stuff to, stains aluminium and clear sight glasses.
Old 30-03-2014, 11:12 AM   #23
aratic
aratic's Avatar
Don't really see a problem with recycled base oil. As a product it's obviously still been tested and meets the approvals on the tin.
2013 Ford Focus ST
Old 30-03-2014, 05:45 PM   #24
xxx000
agree, I think you'll find most mineral oils have a recycled component in them
xxx000 is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2014, 06:58 PM   #25
marg99
Not sure why the comment about recycled mineral oils was relevant to a fully synthetic product which is what the post was about
marg99 is online now   Reply With Quote Multi-Quote with this Post
