Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Shockworks
Shockworks Ford damper specialist located in Melbourne's S.E suburbs. Website Link
Old 06-03-2014, 04:36 PM   #31
dl86
dl86's Avatar
Default Re: BA-FG Monoblock 4 Pot Brake Upgrade
On the front.
http://www.enkei.com/rpf1.shtml#
http://www.enkei.com/size_chart/RPF1.pdf
3798856530SP
18 X 8.5 +30
Thanks Natedog. This will help if the inner diameter of the wheel is the same as my stock GT 19" rim. Should give me a starting point.
dl86 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2014, 06:16 PM   #32
lms_52
Hey Brett,
If they fit 18s im really keen. If need be i can drive up and test fit and bring one of my old factory 19s to see if they fit as well.
Cheers,
Luke
lms_52 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2014, 06:54 PM   #33
natedog
Originally Posted by dl86 View Post
On the front.
3798856530SP
18 X 8.5 +30
These are the stock FPV 19's with the shockworks kit on it, it has 16mm clearance from caliper to inside circumference of wheel, photo attached, so if its the same as your GT rims then you can accurately measure the difference in size with the wheels you have on now I guess....assuming you still have the old Gt 19" wheels somewhere?
2010 mk1 GS sedan with 412rwkw thanks to Pitlane Performance!
KPM Street fighter stage 2 intercooler with 70mm pulley
1000cc injectors
Herrod Fuel pump
BMC air filter
Built tailshaft
Shockworks Coilovers
Shockworks 4 piston monobloc front brake kit
Herrod oil breather and "special" diff breather kit
19x9.5 rears 19x8.5 fronts with sticky Michelin rubber
natedog is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2014, 09:28 PM   #34
dl86
dl86's Avatar
I just did a measurement as accurate as I could and I have 21mm clearance with the Brembo 4 pot and stock GT rim, putting the 18" on that is reduced to about 7mm. It will be really cutting it fine lol
I would need to do a test fit before buying to be comfortable with fitment some how.
Old 20-03-2014, 02:42 PM   #35
natedog
I had to give Brett his test brake kit yesterday and in went my old worn out little rotors.
After driving them around through every day stop start, freeway and a few hard braking tests, all I can do is highly recommend these kits once they are released next month!
The street/track pads that I tested were not dusty.
They were not squealy hot or cold.
The pads did not need heat up to work from cold starts like some street/track pads require.
They did not fade....even with me trying to get them to.....all I did was destroy my rear pads!!!! Poor little rotors, they were coming to the end of their lives anyway :-)
My order is in, I am definitely getting the Shockworks brake kit.
When the Shockworks kit was taken off there was no hint of any higher than normal wear from me "trying" to get them to fade on a couple "test" sessions.
Pedal feel is progressive and predictable, there is no hint of them being unpredictably "grabby" at any speed hot or cold.
Awesome front brake upgrade for the $$$
I must thank Brett for letting me test the kit out.....the fact he was willing to lend them to me to try and beat them up a bit after only having met him a month earlier??
Shows the faith he has in the product to lend them to a stranger basically... and he's a good bloke!
Nathan
1000cc injectors
Herrod Fuel pump
BMC air filter
Built tailshaft
Old 02-04-2014, 04:51 PM   #36
Shockworks
Hi Guy's,
We did some measurements on the brake calliper and rotor and from the centre of the hub to the outside of the calliper is 207.5mm. This should help to understand what rims will fit with our brake upgrade.
Brett
Shockworks is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2014, 11:46 PM   #37
Shonky.
Shonky.'s Avatar
Hi guys, looking good, very impressive how quick you've got this kit to market!!
Say, do you know how much this kit weighs, compared to the factory 355mm/4pot Brembos?
Also, is it lighter or heavier than the 355mm dba 5000 series 2 piece rotor?
Shonky. is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2014, 11:00 AM   #38
Shockworks
Hey Shonkymofo,
We don't have a DBA rotor to compare the weights so a bit hard to say. I know we are around 2 Kg lighter than the factory disc. I will get my hands on a Brembo caliper and compare the difference.
We were able to get to market quickly as we already supply brakes through our Korean partner who support many race teams and also supply brake upgrade for many models in their market.
Brett
Old 03-04-2014, 12:27 PM   #39
Shonky.
Shonky.'s Avatar
Nice one, thanks.
Totally understandable that you don't have a dba rotor, but do you know the exact weight of your rotor?
Old 03-04-2014, 02:36 PM   #40
Stazza_Brendan
Stazza_Brendan's Avatar
Is there an estimated time for these to be on sale?
Seduce BFII XR6T Ute
ZF - Optioned interior - Hardlid - Rapidsystems V4.5 kit - GTX3576R - Crow Cams Valve springs - 1000cc KPM injectors - 20" MC Racing Wheels - DashDaq/Cobalt Gauges - 4in dump/3.5in exhaust system - Shockworks Coilovers - 30mm Swaybar - Shockworks 4pot 355mm front brakes - GT R-spec rear brakes
CPV Tuned to 340rwkw
Stazza_Brendan is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2014, 03:45 PM   #41
Shockworks
Hi Shonkymofo,
Our disc comes in at 10Kg mate.
Old 03-04-2014, 06:34 PM   #42
Shockworks
Hi Brendan,
We are expecting the brakes by the end of the month as they are being prepared for shipping now via sea. We will be airfreighting in a couple of sets but will split the difference in the cost of this if the demand requires this.
We now have the Goodridge/braided line upgrade as an option for the caliper for $180
Old 08-04-2014, 12:15 AM   #43
aktg6et
Just wondering in terms of replacements pads for these, whether they use a generic pad design and are able use replacement pads from other brands (e.g ferodo, bendix, ebc)
cheers
aktg6et is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2014, 03:13 PM   #44
puck_lindsay
If a 19" G6ET rim will clear these, I'm keen.
10 FG G6ET - Rocket-powered lounge suite.
430rwkW/950Nm.
puck_lindsay is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2014, 03:36 PM   #45
Shockworks
cheers
Hi,
I am not sure about the Ferodo or Bendix and looking into this now. If we find something, I will post some part numbers. It is a caliper supplied by Hyundai so will be able to get a part number for there replacement. We are importing many sets of pads for the street and track. We are also working with Howard Reynolds at Race Brakes to make a replacement pad that will be available for both street and track.
Will update what we find soon.
Brett
Old 13-05-2014, 09:16 PM   #46
xr8 007
xr8 007's Avatar
Originally Posted by Shockworks View Post
Hi,
Brett
Same question but with the rotors? Can a generic dba rotor be able to fit? Congrats on the product and look forward to its release.
Build Thread: BA XR8 with all the goodies.
fordforums.com.au/showthread.php?t=11247663
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 13-05-2014, 09:31 PM   #47
natedog
I believe kits may be available as early as next week!
I can't wait!
1000cc injectors
Herrod Fuel pump
BMC air filter
Built tailshaft
Old 14-05-2014, 08:29 AM   #48
Stazza_Brendan
Bit disappointed about lack of information over the last 4 weeks. Nothing about the early sets that were going to be sent. Or the delay. Weren't these suppose to be available last month.
Old 14-05-2014, 09:31 AM   #49
Shockworks
Hey Brendan,
Sorry for the info slowing down mate. I have been in Korea for the past three weeks testing and catching up while back for the last couple of days.
The ship has arrived and we will have full stocks of the brake kits next week. There will be a slight delay on the floating rotor assembly as I was not happy with the pin design and are being air freighted on the 22nd. The fixed rotor and calliper will be ready for sale next week though.
Brett
Old 14-05-2014, 09:35 AM   #50
Shockworks
That is something we will check first before I get carried away. We made the brake upgrade to suit the same offset with the Brembo disc but will test first before I say yes!!
Old 23-05-2014, 08:39 PM   #51
natedog
Hi all,
I am getting the Shockworks brake kit put in next Wednesday, looking forward to some real stopping power compared to the stock calipers I've been thrashing round the track.
Poor little discs......
Will load up some pics once done
1000cc injectors
Herrod Fuel pump
BMC air filter
Built tailshaft
Old 29-05-2014, 12:07 AM   #52
natedog
They went on today....they look gooooood :-)
1000cc injectors
Herrod Fuel pump
BMC air filter
Built tailshaft
Old 29-05-2014, 02:23 PM   #53
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Do you have the rubber or braided lines.
Whitey-AMG is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2014, 02:25 PM   #54
Shockworks
Hi ESP,
We have the Goodridge braided lines for both the BA-BF and the Fg models.
Brett
Old 29-05-2014, 02:26 PM   #55
Whitey-AMG
AWD Assassin
Whitey-AMG's Avatar
Hi ESP,
Brett
I just bought a set - you better not tell me yours are cheaper.........
PM me.
Old 29-05-2014, 03:49 PM   #56
Pepscobra
Call me dirt... Joe Dirt
Pepscobra's Avatar
Sorry if this was already asked, but these new rotors will fit with the factory Brembo 4/6 pot callipers?
2007 BFII FPV Cobra Ute|Boss 302|6M|#23/100
Mods so far:
Billet Products Shifter|X-Force Exhaust|Herrod Oil Breathers|Whiteline Sway Bar|Tein SuperStreets|Kings FOR-303SL Rear Springs|Melling Oil Pump|Mace Manifold Spacers|Powerbond Underdrives|Pacemaker Headers|Ballistic Cats|XFT Custom Tune @ 308.3rwkw|DBA T3 Rotors|Ferodo Pads|Goodridge Braided Lines
Mods to come:
4.11 Diff Gears|Chromoly Tailshaft
I use & recommend:
Castrol|Motorcraft|Mainlube|Penrite
Check Out My Build Thread
Pepscobra is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2014, 04:24 PM   #57
Shockworks
Hey Pepscorba,
We have a different design that suits the Brembo calliper. The Brembo has a smaller disc contact area than our calliper so made a new design for the Brembo's. The Brembo has 57mm of disc contact and our new calliper has 61mm so we have both types.
Old 29-05-2014, 06:45 PM   #58
Stazza_Brendan
Do you have more in black? Just got some rear calipers in black and would like to continue the theme.
Old 29-05-2014, 07:13 PM   #59
Shockworks
Hey brendan,
We have plenty in the black and think it looks very cool for the first time on Natdog's car. We will also offer a couple of options for the colour of the alloy hat like a gun blue and the gold. That will be later in the year once we finish the other Ford range we are working on.
Old 05-06-2014, 04:38 PM   #60
Stazza_Brendan
Not answering PM's?
