30-12-2005, 08:18 AM | #1 | ||
TTG
Can anyone give me advice on the standard 5 spd box, and whether its a common issue where once the car is warmed up it can be a little difficult slipping into 1st when the car is stationary?
There just seems to be a bit of resistance there when you are at lights (say) and try to put it into 1st. However its fine if you put it into another gear initially, then back out and into 1st. Seems to open it up for smoother operation. Common problem to this box, or does it need a service? The car has 138ks on the clock. Cheers! |
30-12-2005, 09:20 AM | #2 | ||
i would say adjust your clutch and see how that goes...
30-12-2005, 09:20 AM | #3 | ||
My ute (AUII xr6) has the same problem, I dont think its anything wrong with it, though i'd be interested in finding out...
30-12-2005, 09:21 AM | #4 | ||
Hey carsik, how exactly do you adjust the clutch?
30-12-2005, 09:24 AM | #5 | ||
beep beep
Normal operation.
My T5 in both my AU and BA XR6 did exactly this. However a transmission flush and new clutch in the BA did alleviate 'most' of the issue (become a 1/50 event rather than 1/5)
Nothing to see here, move along, move along... |
30-12-2005, 09:27 AM | #6 | ||
Well , on my ED there was a nut on the firewall where the the clutch cable comes through - that nut needs to be done up / loosened as needed. My ED was hard going into 1st but this fixed it...
30-12-2005, 11:43 PM | #7 | ||||
AU DIE HARD
:lookedat:
31-12-2005, 08:23 PM | #8 | ||
have the same prob with mine,but more so getting into reverse from stationary.AuII xr6
Red bull gives you wings?: nahhh.... we got our wings from TICKFORD |
31-12-2005, 09:22 PM | #9 | |||
01-01-2006, 09:06 AM | #10 | ||
TTG
Question - Have the repair manual out thinking about changing the gearbox oil as a good NY's day activity. However the author appears to have the entire box out in the photo's (not going to happen here) so i'm curious to know whether you guys know of a method of draining/refilling in the absence of a workshop pit etc...
I have ramps, jacks, etc however these will hardly keep the car level, and I note that filling the box appears to require the car to be on a level situation. Ideas? |
01-01-2006, 11:40 AM | #11 | ||
Team Urinal Cake Racing
use a hand pump lol!!!
01-01-2006, 11:50 AM | #12 | |||
Yep, AU's are the same. I used to have this problem on my AU1 XR6, and adjusting the clutch used to fix it. It does chew through clutches though... I've had the car for 2 years, and gone through 5 clutches... I drive it hard, but i wouldnt have thought it was hard enough to go through 5... any one else chew through clutches? |
01-01-2006, 02:47 PM | #13 | |||
above that there is a filler plug, undo it, and run a piece of hose up through the engine bay with a funnel, and the other end into the box obviously, and poor the oil in.. takes 1.9L to fill.. this is the only way i managed to do it without having a pump or anything.. xr6stu, sounds like you've got problems with your clutch type.. next time it goes, try a heavy duty excedy or xtreme... |
22-01-2006, 07:52 PM | #14 | ||
TTG
Just done an oil change this afternoon, included the lubrizol additive, and it seems problem sorted. Plus its smoother operation between the gears. Shifts just like new!
Thanks for your advice! |
