Old 22-09-2013, 11:13 PM   #1
naddis01
naddis01's Avatar
Default Improving FM reception a home stereo
Ok guys, I have a stereo/hi fi out in the shed and the radio reception is terrible. It currently just has a single wire for FM and a loop for AM. How can I improve reception, moreso on FM? Is it possible to use a car antenna? I went into a local electronics shop and they pretty much said there is nothing.
naddis01 is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2013, 07:51 AM   #2
duaned
duaned's Avatar
Default Re: Improving FM reception a home stereo
A set of rabbit ears should do the job. $5 from your local cheap as chips shop. They are VHF so work OK on the FM band. Just make sure you also get a pal female - female joiner as well.
duaned is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2013, 10:57 AM   #3
The Yeti
The Yeti's Avatar
^^^^thanks, I'll also give this a go as I'm suffering the same problem
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2013, 11:44 AM   #4
naddis01
naddis01's Avatar
Thanks for the tip. How do I attach the rabbit ears? To attach the existing wire you just push it in and flip the little clip over to hold it. There are 2 of them for both FM and AM (4 in total) but the FM currently just has the wire in one of them.
I can post a pic later if that doesn't make sense.
Old 23-09-2013, 07:41 PM   #5
redxm
64 Deluxe 4 door
redxm's Avatar
The 2 connections for fm.. designed for coax cable. Inner conductor and braid. Chop chop on rabbit ears and use the inner and outer. I have a purpose made fm antenna for my shed radio, bit like a large tv antenna. An old vhf tv antenna would work too.
XM Deluxe
FG XR50
BA Pursuit Ute
redxm is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2013, 10:52 PM   #6
dave351cid
playing in my big shed
dave351cid's Avatar
i had no radio reception at all inside my new house so i fitted a $19 car antenna to the roof with standard TV coax cable. tandy shop had a conector that i used to join the small coax from the antenna to the larger coax. tv coax goes to a normal tv wall socket and a lead from my sterio to the wall socket.
i have a panasonic sterio that has a provision at the back for a tv style antenna plug.
`75 XB FAIRMONT sedan . mushroom beige, injected 351, toploader, 9inch
`10 FG XR50 Turbo ute. Nitro blue, 6 sp Auto, Leather trim.
`04 BA RTV tray back, Red, V8 auto,
`04 BA XR6 Turbo sedan. Blueprint. auto, Leather trim.
`03 BA XLS ute . Acid Rush, factory lpg, auto,
`48 TEA20 Grey Ferguson,
`62 Willys 6-230 , 4x4 light truck
`04 Yamaha TTR 250
dave351cid is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2013, 11:15 PM   #7
ebxr8240
Performance moderator
ebxr8240's Avatar
If antenna can be outside it'll work better.. Esp if steel shed ..
Daily driver GTE FG..
Old 30-09-2013, 10:51 PM   #8
naddis01
naddis01's Avatar
Thanks for the tips guys. Dad recently pulled down a TV antenna so I permanently borrowed it for an experiment. I just tried it and the reception is much improved even with the antenna just lying on the bench in the shed. So looks like I will stick it up outside somewhere.
Thanks again! I have no idea what the guys at Dick Smith and another electronics shop were on about. They said there was nothing to really do it with.
Old 01-10-2013, 01:05 AM   #9
aussie_rabbit
Two connections = think of them as left and right, use equal lengths of wire -
option 2 - antenna often seen on 4x4's with a spring base, attach to the outside of the shed
aussie_rabbit is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2013, 01:10 PM   #10
Bundy
All Ford Club Life Member
Bundy's Avatar
A VHF antenna is perfect for the job, most will comfortable do a range of 30 to 300Mhz
The FM range is 87-108Mhz
Begin that the shed is a big metal box, mounting an external AE is the natural option.
Old coaxial tv cable is also well suited for the job, use the centre core and only connect the shielding at one end, ie the AE end.
Worked AU XR8 Ute - Toy
Std FG XR6T Ute - Daily
Supercharged BA 6 Ute - Wife's daily
351W F150 93 XLT 4x4 Supercab
Bundy is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2013, 02:09 PM   #11
aussie_rabbit
While a pre-digital TV antenna works well you do need to face it in the general direction of the source as they are directional.
Simple antenna such as these -
http://www.ebay.com.au/itm/SPRING-BA...-/251011892996
are easy to fit, cheap and work well.
