Old 28-08-2012, 11:12 AM   #1
ss11
Default LW Focus Powershift Rattle
Hi there
I recently picked up a LW Focus Trend auto, done around 450km's. The engine and general drive is perfect however recently I've been noticing a rattle between gear changes. Not all the time, but mainly at low speeds when the engine is under load (like going up a hill on low throttle / low speed). There's also a clicking type of sound when reversing the car.
Is this something common with that transmission or should I take it to the dealer?
Thanks in advance
ss11 is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2012, 11:40 AM   #2
DeKa
Default Re: LW Focus Powershift Rattle
The rattle between gear changes sounds like pinging. Are you running it on 91 octane? It will run better on 95 or 98.
DeKa is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2012, 11:53 AM   #3
obd
Could be the clutch pack in the gearbox causing rattle, best have the dealer look at it.
obd is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2012, 08:08 PM   #4
Dustproof
Dustproof's Avatar
This is my thoughts too, run the car on 95 or 98. The engine tune changes as you use the throttle with the DSG, you will get pinging if you use low octane fuel, especially the rubbish they sell us here.
1400 GTR Goes like it has a Kwaka up its butt
Dustproof is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2012, 10:53 PM   #5
Jayman007
Not a Ford owner....yet.
Having the same issue, will be getting it looked at soon. Focus Trend 2012.
Jayman007 is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2012, 03:56 PM   #6
ss11
I took it to the dealer and they basically said its a common 'fault' in the car. They had a printout ready titled 'operating characteristics of the powershift'; details different sounds and noises that the powershift makes, all with the point that its expected (Fiesta has the same issues).
Having said that, the sounds aren't as frequent now (driven roughly 2200km's). Still get the occasional rattle / vibration, but I find that the less you 'feather' the car, the less it happens.
Old 01-10-2012, 06:21 PM   #7
Fiesta_Man69
If the dealer is saying it's a "characteristic" of the car I'd be very concerned.
Fiesta_Man69 is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2012, 10:44 PM   #8
Fez WQ
All is normal here, If you understand how they work. The noise is fairly normal. Drive it harder they love it. Just had a WT powershift for 3 weeks great car takes a little to get use to the feel but .... when you do its great and good on fuel
Fez WQ is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2012, 10:49 PM   #9
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Forget the computer controlled clutch, give me one clutch and a manually operated pedal and gear lever with 6 forward gears.
Old 02-10-2012, 09:09 AM   #10
ss11
Managed to find a link to what the dealer gave me. Here it is
http://www.fordtechservice.dealercon.../pdf/2DPS6.pdf
Im getting the occasional low speed grinding...except not at 2mph, anything less than 20kmph
Old 02-10-2012, 02:25 PM   #11
Yuecwy
HI, hope your noise is NORMAL.
I have similar experience BUT as the NOISE gets louder, I decide to let ford ppl to verify whether the noise is normal or not.
TURN OUT it is not the normal noise LOL
AND my car has now been in serviced for 1 week already and FORD dealership still waiting for some parts to arrive so they can install them and reprogram the car.... they told me that it would take a bit longer than 2 week = =...
sorry not really a car kind of guy..very new to car...so I already tried my best to describe my situation to you : )
Yuecwy is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2012, 02:26 PM   #12
Yuecwy
check out my post if you find anything relevant to your case..coz i have video-taped the noise...which you can use as a comparison to verify if your noise is normal ...
Old 02-09-2013, 01:58 PM   #13
jonohoang
Well I thought the occasional gearbox rattles were 'characteristic' and the rough changes were based on it being a DCT.
Recently it had developed a grinding noise from 4th into 5th.
Took it into Ford today and they advise that it needs a new gearbox. Dosn't really provide much confidence in the longevity of this DCT, considering the car is only 1 1/2 years old!!!
Hopefully the new gearbox is better.
jonohoang is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2013, 03:26 PM   #14
Jayman007
Mines coming up to it's first service 15K, after the car warms up, approx 45mins worth of driving, the sound comes back... it's between the gear change of 2nd to 3rd gears... very annoying.. the more you drive...the warmer it gets... the louder it becomes. I'll be raising it with them , as they said that after around 1,500k's it should settle.. I spose it did but, after the car warms up, it's back.
Old 03-09-2013, 08:02 AM   #15
Dustproof
Dustproof's Avatar
I have a Diesel with DSG and it is fantastic, I would change the shift points a little but that is my only gripe. I get no noises at all so I don't understand what could be wrong, I do believe running the car on 95 until it is run-in to around 10,000kms though. Tight engines will ping, this will go away when you ease off the accelerator, if this is the case problem solved.
Old 03-09-2013, 08:30 AM   #16
marg99
I thought the Diesel has a different transmission to the petrol engine
Old 03-09-2013, 08:39 AM   #17
wombat66
Yes. It has the wet clutch.
2015 TF MkII Kuga Trend Powershift Diesel with Tech Pack (Deep Impact Blue)
wombat66 is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2013, 11:29 AM   #18
Russ
Russ's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: Very helpful and gracious with photoshop work to help others..
So how did you find the diesel ran on 95 whilst running it in
Russ is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2013, 08:10 AM   #19
Dustproof
Dustproof's Avatar
It coughed a little I didn't know the petrol version had a dry clutch, I gather it is a single plate as well. Yes the Diesel has a twin wet clutch pack system which is made by Getrag, it is better than the VW unit by far.
