Old 02-06-2013, 08:18 AM   #1
mutanti
Turbo
mutanti's Avatar
Talking Focus MK 2 Tricks....
Has anyone heard of Any tricks - Tweaks that you can do in the Focus.
EG : Bring up Digital Speedo on Dash instead of the traditional Dial.
This I would like as I XF GHIA has it, My BA Had It, My FG Had it ??
Change Settings within Onboard Computer system like the Seatbelt Chime hack for the BA's & FG's ( FG Seatbelt one below on Bottom)
Connect Via bluetooth for More than you normally would see data on what you can modify.
Have seen the Bluetooth Dongle OBD thing Link
Just Some Ideas Going through my head - I am sure there would be some.
I am Sure there are hidden Bits in there somewhere with what I have seen cars over last few years do.
( FG - ignition on, wait for airbag lights etc to go out
buckle unbuckle 9 times
wait for few seconds for seat belt light to start regular .5 second flash.
All done.
To go back to the annoying warnings repeat above proceedure.)
mutanti is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2013, 08:58 AM   #2
mutanti
Turbo
mutanti's Avatar
Default Re: Focus MK 2 Tricks....
Just to Add a bit more detail there are Chip upgrades, Bluetooth Dongles, Programmers of all sorts,
If anyone has Done more research on some of the above how about adding details in Post below of Type, Details like performance upgrade ( KW - Torque , price ) and weather it affects Warranty... ETC
Old 02-06-2013, 12:50 PM   #3
In Focus
http://www.fordforums.com.au/showthr...ighlight=trick
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red.
Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White.
Old 03-06-2013, 08:31 AM   #4
mutanti
Turbo
mutanti's Avatar
I Have tried the Speedo thing
Hold right OK and Ignition on but there is no way i can see from there to Lock in digital Speedo..
Get all the other options mentions in the other post but No setting to change, (Still Cool tho )
The Hold Unlock and all windows down Works !!
Old 05-06-2013, 09:10 AM   #5
mutanti
Turbo
mutanti's Avatar
So What are these like.
What are the good and bad.
Would I lose Warranty ?
LINK
Old 05-06-2013, 09:24 AM   #6
marg99
raise the fuel pressure have been known to cause fuel leaks later on.
marg99 is online now   Reply With Quote Multi-Quote with this Post
