Old 09-04-2013, 07:45 PM   #1
edroders
edroders's Avatar
Default camber castor kits and SL's
Hey Guys,
just bought myself a set of king springs SL's and lowered monroe gt shocks, for my AU2 Fairmont Ghia. The question i have is will it require camber castor kits front and rear or just one or the other.
Thanks Roders.
"Insert witty signature here"
edroders is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2013, 08:10 PM   #2
Papa Smurf
Papa Smurf's Avatar
Default Re: camber castor kits and SL's
I changed the front springs on my AU III XR6 live axle and just changed the top control arms using BA XR type brackets. They have a longer bolt and have spacers designed to work with lower suspension heights. Cheaper than after market kits.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2013, 08:13 PM   #3
b2tf
not here much anymore
b2tf's Avatar
Would put one in the front myself, I have had a KMAC adjustable one in a previous car and it was great. Never had an alignment problem with it.
2024 F150 XLT
Old 09-04-2013, 08:14 PM   #4
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
If this helps you at all, I have an AU3 live axle and installed some king lows all round about 6 weeks ago.
Ride heights at the front from the centre cap to the lip of the guard measured 380mm. After king lows were fitted it was 355mm.
Rears 360mm before and 345mm after.
It is duel fuel so there is a tank in the boot.
Camber measured 0.8 degrees at the front before the drop. 1.4 degrees afterwards.
I have brackets with the long bolts on the upper arms so stuck 6mm of shims to get it back to 0.8 degrees.
It will increase your camber. If you dont adjust the camber, you can always run a little more toe in to make everything wear evenly, but I suppose there is a limit to how much you can do, before it starts becoming impractical.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2013, 08:18 PM   #5
Whoosha
AU DIE HARD
Whoosha's Avatar
Its a bit hit and miss some do some dont
Originally Posted by Riksta
Old 09-04-2013, 08:19 PM   #6
XAO71
Stalker
XAO71's Avatar
I bought TE 50 camber caster kit from ford, 1/2 the price of aftermarket ones.
The cars we drive say a lot about us.
Second Xa Build and current.
https://fordforums.com.au/showthread.php?t=11461551
First XA Build .....
https://fordforums.com.au/showthread.php?t=11300908
XAO71 is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2013, 08:32 PM   #7
edroders
edroders's Avatar
ok so just the fronts then?
Old 09-04-2013, 09:27 PM   #8
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
You never know until you fit the springs and get the alignment done....For what it is worth, I have been able to get at least 1 degree of camber out of AU's factory control arms.
BA's have about the same length bolts as the AU arms.....The spacers (factory shims actually) that have been referred to are standard fitament on all AU through to FG Falcons (and earlier models)....Those shims are spot welded in place to take up the manufacturing differences which occur...So finding the right ones will be hit and miss.
Summing up....Just have the dollars "just in case" you need a camber/caster kit.....99% of the time, they're not necessary...
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
Old 09-04-2013, 09:53 PM   #9
robbyj
Rob
robbyj's Avatar
have had king spring superlows for 4 years, had 20's, 15's and 17" tyre's, never need a camber kit
99 liquid silver AU Classic -Sold
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
Old 10-04-2013, 06:52 AM   #10
Sox
RIP...
Sox's Avatar
You most likely won't need a camber kit.
In fact camber kits are nothing more than upper control arm brackets with longer studs and a pile of shims. Unless you're talking about the ratchet ones, which I would avoid anyway.
Lowering increases negative camber, which is usually a good thing, within reason.
If there's too much negative camber (more than 2deg), then you can add a couple of shims to the standard mounts and most likely get close enough.
As someone else mentioned, just add frag more toe in, and all will be well.
Oval Everywhere...
