Old 27-12-2005, 04:23 PM   #1
dfwcomputer
Default Cat Converter
hi,
will the au xr6 98 model run fine with out the cat converter.
Back in the XE days it was common practice to remove the cat converter giving you a tougher note and a noticable performance gain.
is thgis still the case?
dfwcomputer is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2005, 04:27 PM   #2
Gilesie
You gotta pay to play
Gilesie's Avatar
I am yet to see an XE with a cat converter, they all used leaded fuel.
Regards Gilesie
AU I Forte Wagon 4.0
Dodge D5N Twincab (Project)
2003 Mazda Bravo (work truck)
1979 F100 Ambo
Gilesie is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2005, 04:30 PM   #3
dfwcomputer
sorry XF it's been a few years
Old 27-12-2005, 04:32 PM   #4
LUXO_8
windsor user
its illegal to remove (or gut out )a cat converter and will result in a ~$10,000 - ~$20,000 fine...... plus at best you'll gain a whopping 1-4 rwkw
just dont do it, it is there for a reason - to take the nasty cancerous crap out of the exhaust.....
Old 27-12-2005, 04:33 PM   #5
stiddy
stiddy's Avatar
Originally Posted by dfwcomputer
hi,
yes it will sound different, and yes you will get a slight increase in performance..
but will also land you a $20,000 fine if your caught without it...
for what its worth, i'd suggest dont do it.. the standard cats are already fairly "high flow" or replace it with a bigger high flow cat?
like 3inch or something..
stiddy is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2005, 04:35 PM   #6
stiddy
stiddy's Avatar
Originally Posted by MADNC_8
its illegal to remove (or gut out )a cat converter and will result in a ~$10,000 fine...... plus at best you'll gain a whopping 1-4 rwkw
i was told it was $20,000 fine........
Old 27-12-2005, 04:37 PM   #7
LUXO_8
windsor user
its somewhere inbetween 10 and 20k, depends how lenient they are on you i guess...
"~" means around / approx :
Old 27-12-2005, 04:41 PM   #8
dfwcomputer
It's illegal to do a lot of things
e.g Have you ever exceeded the speed limit?
Cats were not around in my day and i still think there a load of useless crap.
Old 27-12-2005, 04:45 PM   #9
LUXO_8
windsor user
ok die of cancer, see if i care....
was just letting you know what youre in for......
Old 27-12-2005, 04:46 PM   #10
dfwcomputer
fully understand no pun intended just commenting.
Old 27-12-2005, 04:48 PM   #11
buickman
buickman
buickman's Avatar
They were not around when I got my License in 1972 & neither were PC computers. But everything changes in life. You asked the question & others have given you feed back. Remove it its your car if you want. But be prepared for any fines if you do get caught
buickman is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2005, 04:51 PM   #12
dfwcomputer
My question was actually
not how much it would cost if i got caught.
Old 27-12-2005, 05:01 PM   #13
stiddy
stiddy's Avatar
yes it will run fine.. like i said before..... but was just letting you know its not really worth it and what could happen..
speeding yes, everyones done it.. but $200 fine vs $20,000 fine...
Old 27-12-2005, 05:08 PM   #14
jonbays
TL40 Wagon?
Really not worth it!
Most people on the forums have broken a few road rules and regulations before I am sure they would not worry too much about legality as a major concern if it worked. It doesn't the stock AU cat is pretty good and replacing or emoving it isn't a worthwhie performance mod.
Just ask Stiddy about a tough sound if you heard his XR6 on the dyno you will know what i mean it barks.
Old 27-12-2005, 05:11 PM   #15
LUXO_8
windsor user
there are plenty of other performance mods you can do to the 6 without worrying about the cat....
cam, intake pipe, exhaust, are just 3
Old 27-12-2005, 05:28 PM   #16
dfwcomputer
yer i here ya
Spose the good old days are gone forever.
Intake sounds like a good starting point followed by exhaust.
Old 27-12-2005, 05:29 PM   #17
stockstandard
The reason why you didnt have cats back in your day is bacuse the fuel was different back then (leaded vs unleaded).
Removing cat means pumping out dangerous chemicals for everyone else to breath and risking potentially huge fines all for the sake of a power gain/exhaust note change that you will bearly notice.
Originally Posted by casper
Yeah, the car is ugly, I can live with that.
stockstandard is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2005, 05:38 PM   #18
dfwcomputer
It's not that i don't understand cats it that i wonder if they actually do what there meant to.But i think where past that anyway.
Old 27-12-2005, 05:39 PM   #19
dfwcomputer
Thanks for the tips a definate look see i think.
Old 27-12-2005, 05:48 PM   #20
LUXO_8
windsor user
i know of cars making some very decent power with the stock cat in place, extractors, exhaust, cam and intake mods, and the cat is still not a restriction...
really its only when you start getting into the realms of supercharger/turbo setups that the cat is a restriction i think....
Old 27-12-2005, 05:58 PM   #21
Casper
Contributing Member
Casper's Avatar
The cat on an AU has almost ZERO impact on rwkw, they are extremely overengineered for the I6. Taking it off will be more trouble than its worth and cost you about the same as a decent intake setup (and the intake would probably be more effective).
Also, any reference to gutting your cat or removing it (unless you are living in NZ) will see your posts removed on the subject.
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2005, 06:12 PM   #22
buickman
buickman
buickman's Avatar
Your better bet would be to put a 3" pipe with hi flow filter & good sports exhaust system. Then down the track look at the engine & chip mod.
Old 30-12-2005, 12:58 AM   #23
Sleeperau
Highway Taxi
Thumbs up Intake?
I HAVE SEEN THAT PHOTO MORE THAN ONCE, SAME AS MINE & BUICKMAN PUT ME ON TO IT!
P.S iT WORKS!!
Close only counts in Horse Shoes & Hand Grenades. :evil_laug
Sleeperau is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2005, 02:08 AM   #24
Mechan1k
Mechan1k's Avatar
You can have my standard cat ... it's actually gutting itself at the moment.
I'll be getting a new one soon with some nice extractors .... hee hee
Old 30-12-2005, 07:49 AM   #25
buickman
buickman
buickman's Avatar
P.S iT WORKS!!
LOL Hey I will put it on the dyno one day to see if it makes any RWKl difference
