And the obvious...all windows were UP all doors were closed completely.
Today I had a few tradies come over so being as nice as I am, I took the focus out of the garage so that they could use it to cut up some architrave etc. without getting wet. Parked the focus in the street (there's a reasonably steep incline on my street and the car was pointed up hill). This evening I go to move it back inside and notice that my stereo cut out (aftermarket amps under seat). I put it in the garage and have a look to find that it is FARKEN SWIMMING IN A POOL OF WATER! The left side of the vehicle front and back has pooled about an inch of water. I didn't notice when I got in as it was dark and the driver side was dry. Upon inspection and removal of the plastic grill/grate near the wipers at the base of the windscreen I can see that, that area contains some wires in conduit which lead downward, I assume INTO THE CABIN. I upon putting my hand behind the passenger side carpet under the dash, its all wet in there. It's obviously coming in and down from behind the dash somewhere. Anyone have any problems???? If not, BEWARE. I am livid! Car was perfect up until now. And this is a pretty big **** OFF PROBLEM! HELP! Can anyone confirm that the area under that plastic grate leads into the cabin? Is that where fresh air is drawn in for the HVAC and could this be the source of the flood?? |
The older model focus had a leak in the boot when the water would leak in through a panel join under the tail light. Not sure where this one is coming from but I would take it to ford, you may be able to get it fixed under warranty. If it is as serious as you say, it might even generate a recall.
Will get onto ford first thing this morning. Gold luck to me, I guess.
#4 | |||
Where to next??
If the leak was from a factory defect then it is certainly a warranty issue.
___________________________ I've been around the world a couple of times or maybe more....... |
Car is booked in for a look in on Monday. Lets hope they can find the source of the leak.
The boot is as dry as a bone so not an issue there. Having spoken to Ford staff this morning, it could be a result of poor drainage due the angle at which the car was parked on the hill. Water didn't flow straight down the windscreen and away, it may have pooled at the base of the windscreen and flowed back through the air in takes for the HVAC. THIS SHOULDN'T HAPPEN! No matter how or where the car is parked. Someone should have mentioned to engineers that the earth is NOT flat and sometimes we have to park on in/declines in the rain! |
I had the exact same thing happen to my LR focus and it was caused by the pollen filter which is indeed under the windscreen on the passenger side. I took it to the dealership and had it fixed, there is a TSB for it on the LR not sure about your model though. Hope you get it sorted soon.
Comforting in a strange way to know that my cars problem not a random freak occurance.
I'll be sure to post up what Ford have to say once I get more info. |
Moff-fan
Passenger cabin of my Fiesta flooded in a similar fashion less than a year ago (but the underlying "gaps" had been there for a while- assuming since it was built). For mine it was multiple leaks- one was a body seam!!!!
Mine has now also leaked into the boot in the past week and today I have more issues that require warranty claims (I believe). So share your pain definitely. Make sure they replace the carpets and underlay too when the repair it, otherwise god know what the smell will be like after a few months/years. EDIT- oh, and my leaks occurred on relatively flat surfaces, so I would be very surprised if the incline had anything to do with yours. Put it this was- my sister's '98 Toyota can deal with rain on an incline, so our cars should be able to put up with it no matter what!! Double edit- damn, just realised your Focus is the awesome red one with the cool mods. So sorry, that is a lovely car : (
MY11 Fiesta Zetec 5sp in Vision... GONE!!!! ![]() Now rocking a 2012 Suzuki Swift Sport! ![]() Last edited by brydie76; 02-02-2013 at 09:06 AM. |
Thanks for the reply Brydie76. I'll stop complaining now given the problems you're having :( It goes in tomorrow morning so I hope the problem can be replicated so that a fix can be implemented.
I've had the car in heavy rain/storms before with no issues at all. The only difference is the position in which it's parked (on the hill). Just that weekend I installed a dash cam so I have footage of where and how it was parked, hopefully that gives them a clue or two as of whats happened. *shrugs* We'll see ![]() |
Moff-fan
Haha, feel free to complain! Shouldn't have this issue even once with any car, so you definitely have a right to be complaining about this : )
The way you describe it definitely sounds like the parking position contributed to it flooding, yeah. Good luck with the dealer tomorrow, they are normally quite good when you tell them the car is leaking (especially if you can show them what areas were/are still wet), the time is often in finding the source and putting all the bits back together after they pull the car apart to find the damn leak!!! : )
MY11 Fiesta Zetec 5sp in Vision... GONE!!!! ![]() Now rocking a 2012 Suzuki Swift Sport! ![]() |
It will be when Ford replace the pollen filter which is under the passenger side windscreen cowl.
They tend to break the clips and therefore it doesn't seal properly again and when it rains the passenger footwell fills up with water. Happened to my LR Focus
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
In the LT series they moved the pollen filter inside the cabin Are you sure it is still in the engine bay on LW series?
#13 | |||
Molten Orange Maniac
mrmavx |
#14 | ||
I would check the plastic cowl that should sit flush against to bottom of the windscreen. It covers a chamber on the engine side of the firewall and while that is supposed to drain away it may not have worked if parked on an angle.
#15 | ||
I have some encouraging news.
At least they were able to find the source of the leak and seal it. Currently carpet and sealant is drying. I couldn't get specifics of where the leak was coming from but I will be sure to chase that up when I pick it up. Some mentioned that I should have the carpet replaced but to be honest, if they can dry it thoroughly I would prefer they leave it in place and not have to pull more of my car apart. We'll see what comes of this from here. |
#16 | ||
Where to next??
Try and leave the carpet in if possible. Leave it in the sun with all windows down as much as you deem safe. Request they explain exactly where and how it leaked so you know where to look should it happen again.
#17 | ||
Will do. They said it would be ready tomorrow but I said keep it there and air it out for another day to be sure. Hopefully I get some answers.
#18 | ||
They didn't seem too fussed about the whole ordeal. Meaning it appeared that it didn't take them long to locate the source of the leak, seal, test, dry and reassemble.
Paper work states that a body seam behind the passenger side wiper motor was the source of the leak. Fingers crossed it will never happen again. I certainly won't be parking up hill in any rain, that's for sure! |
