Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > ASL automedia
ASL automedia Specialising in the upgrade of BA/BF/Territory and FG audio and visual systems. We also repair all Ford (OEM) car stereos and produce OEM quality wiring harnesses. Website Link
Old 02-11-2012, 05:45 PM   #1
buddy92
Default 6 Stacker.
Hi.
As ASL knows I got a G6ET ICC upgrade for my car, yeah Ford couldn't do this and that.
Anyways, I put the single stacker from my old one in so I can use it, if I put the 6 stacker in it, will it work or will I have to take it back to Ford for them to do anything?
Can I swap the boards from the CD players to make it work, but keep the 6 CD's or is Ford the only solution?
buddy92 is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2012, 08:06 AM   #2
FADI75
Sponsor
Default Re: 6 Stacker.
Originally Posted by buddy92 View Post
Hi.
hi
all depends, is you six stacker single climate and is yuor car is a single climate? if this is the case then you will need ford to use their IDS to reprogram the changeover
cheers
fadi75
FROM FALCON BA THROUGH FGX, TERRITORY SX THROUGH SZ - ICC UPGRADES, REPAIRS & INTEGRATION SPECIALISTS
AUTHORISED FORD REPAIR CENTRE
website: www.aslautomedia.com.au
email: info@aslautomedia.com
AUDIO INTERFACES, REVERSE CAMERAS, SATELLITE NAVIGATION & VIDEO INTEGRATION ON FACTORY COLOR SCREEN
FADI75 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2012, 08:50 PM   #3
buddy92
Yes Salim put my screen to single zone when he sent it back to me. Not sure what the CD player is set to. Is there any chance of it working if I pull it all out and try it? Ford is my last resort, really hate Ford here with a passion.
Old 11-11-2012, 09:25 PM   #4
Silver Ghia
Silver Ghia's Avatar
Buddy, perhaps checking the audio menu to see whether it has the graphic equaliser screen may give a clue to what its programmed for. The non-premium setup doesn't have the graphic equaliser screen (see owners manual).
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2012, 02:06 PM   #5
IWANTANF6
The CD player has nothing to do with climate control. If you put the 6 indash
and it shows "security code", you need to take it to a ford dealer to clear it.
STEEL G6E Turbo
IWANTANF6 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2012, 09:16 PM   #6
buddy92
No there's no Equalizer settings.
