Old 18-05-2012, 06:31 PM   #1
Default Brake refurb cost
2008 TDCI done 90000kms.
Need to get it in and get brakes done front and rear-never been touched.
How much will it cost stock parts and labour non Ford service people approximate?
kevino is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2012, 08:14 PM   #2
Neale
Neale's Avatar
Default Re: Brake refurb cost
have you checked how mutch is left on the pads, mine lasted longer than 90,000. Still never changed the rear & have done 110,000 plus track days.
The minimum thickness of the pads is 1.5mm.
The disc thickness is 25mm when new & should be repaced when it reaches the minimum thickness of 23mm or is heavily grooved
You can buy the parts at supercheap/repco or other brake places & change them yourself if can use a screwdriver & allen keys.
I can post a how to if you would like.
Neale is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2012, 09:58 PM   #3
Thanks Neale. I,m hopeless mechanically even though my dad was a mechanic.
The guy I will use is pretty trustworthy, you must do a lot of straightline motorway work like me.
Old 18-05-2012, 10:20 PM   #4
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Just got my LV focus back from its 35k service and was told there was 70% thickness on front but 50% on back. When I asked if he was sure it wasn't the other way round he said it was a characteristic of the car to wear the rears faster than fronts. I'm still not convinced.
Would like to see a 'how to' Neale if you have the time. How different is the stopping hardware between models?
___________________________
Old 18-05-2012, 10:29 PM   #5
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
I call BS on the brakes, FWD usually have 80% front to 20% rear brake bias.
Old 18-05-2012, 10:41 PM   #6
Yellow_Festiva
Where to next??
Exactly what I was thinking Damo.
Old 18-05-2012, 11:05 PM   #7
rand0mn00b
ditto. BUT... (always a big but) ...
more than a few focus owners on here (me included) had the rears wear out before the fronts - I thought the handbrake was stuck or something like that
and i can tell you I wasn't BSing because I inspected the pads and rotors (and then later changed them) myself
couldn't give you a definite answer why but the factory equipment rotors all round don't last too long. it would appear they to wear out about the same rate as the pads
remember that the front rotors and pads are larger and thicker while the rears and smaller and thinner which is why it's not always a good idea to cheap out or go lower grade on rears - just my experience thus far on the focus so far
rand0mn00b is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2012, 04:32 AM   #8
steambao
steambao's Avatar
I got my front and rear discs for $325 (off ebay, picked up from a place in north west melbourne), bought pads off ebay (USA) for ~ $120 and got everything fitted at my local Ultra Tune (with Major service, included in price) for $350ish. I think the brakes themselves (labour) was only about $100 - as you only pay for time spent since supplying own parts.
Total cost (for better than stock) ~ $550.
Ford Focus LS 2007 Zetec
K&N Apollo CAI, Custom 2 1/4" Cat-back Exhaust, RDA Slotted Rotors, EBC Greenstuff Pads, Continental Extreme Contact DW Tryes, Red Calipers (+10kw)
steambao is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2012, 01:39 PM   #9
Neale
Neale's Avatar
Iwill post it up when I get a chance.
Im calling BS on the rears wearing faster. have a look at the amount of brake dust on the fronts compared to the rears when you dont clean them for a while. Thats proof enough for me.
Old 19-05-2012, 02:24 PM   #10
DZFord
DZFord's Avatar
My original brakes wore out on the rears before the fronts. And it wasn't BS, I also saw the proof with my own eyes.
Old 19-05-2012, 02:25 PM   #11
DeKa
Funny you mention it - my LV rears have HEAPS more brake dust than the fronts, and guess what? My rear pads are more worn than the fronts...
I wonder if there's some sort of 'anti dive' programming in the ABS/Stability Control system?
DeKa is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2012, 04:35 PM   #12
marg99
More like issues with the hand brake system in the rear calipers not releasing quite enough.
marg99 is online now   Reply With Quote Multi-Quote with this Post
Old 19-05-2012, 04:41 PM   #13
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
it is fact that some cars will wear the rears out quicker than the front.
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2012, 06:18 PM   #14
WILDB
WILDB's Avatar
Alot of Focus' and Mondeos I've seen have worn the rears out quicker than the fronts.
For instance one of our vehicles at work wore the rear pads out in just shy of 60k and the fronts are still good at >75000km.
WILDB is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2012, 07:05 PM   #15
Yellow_Festiva
Where to next??
Well there you go, myth busted LOL thanks for clarification.
Old 19-05-2012, 09:01 PM   #16
ratter
ratter's Avatar
Don't worry, until a few years back, I would have agreed with you totally
Old 19-05-2012, 09:54 PM   #17
Superoo
Mondeo TDCi / BA XR6T
Superoo's Avatar
Had to change the rear pads on my Mondeo before the fronts.
03 Mercury Silver XR6T
07 Blue Ambition Mondeo TDCi Hatch
Superoo is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2012, 11:43 PM   #18
rand0mn00b
this is the only explanation for the above I can think of. on factory pads and rotors my fronts also became dustier, sooner.
that's what I suspected too! unless the rear pads and rotors from factory are softer than the fronts. I'm on a set of after-market now that are pretty even all round. doing a service soon so I might take a peek at the brakes.
any insight as to why that might be?
edit: back on topic: rotors were RDA blanks and QFM HPX pads all round cost $437 delivered from GSL RallySport. this was almost a year ago though so maybe give them a call in case prices have changed. wouldn't know how much labour cost I did it myself.
Old 01-07-2012, 04:29 PM   #19
leakey
leakey's Avatar
Neale, did you ever post those photos or a how to anywhere?
I had a dig around, but couldnt find anything. Be cool if you still could mate.
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR
leakey is offline   Reply With Quote Multi-Quote with this Post
