Old 20-06-2012, 03:21 PM   #1
canuk7
Default rear bumper mounting brackets
Hi guys,
I need to replace two mounting brackets on the rear bumper of my au1. These are the steel brackets that are attached to the plastic cover with large pop rivets, the bumper is then attached the car frame. If anyone has done this before I would appreciate any tips on how to remove the pop rivets holding the old brackets on etc.
Thanks
canuk7 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2012, 03:53 PM   #2
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
Default Re: rear bumper mounting brackets
try and punch the pin (in the centre of the rivet) through the centre of the aluminium part first.
once that is done,
then you just need to drill through the aluminium part.
and you are ready for the next one
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2012, 03:56 PM   #3
canuk7
Thanks my67xr.
Old 20-06-2012, 07:29 PM   #4
david lee
you can also grind the heads off with a small angle grinder have you got new rivets
david lee is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2012, 09:24 PM   #5
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
The way to do it is to drill thru the top of the rivet with a drill the same size of the rivet hole. In this case 1/4 inch.
You drill until the head comes adrift. When it does, the bar will be seperated from the bracket. Then the remainder of the rivet will be able to be pushed out.
Don't grind, you won't be able to punch the rivet out.
This is how it is done.
Have fun.
MNM96 is offline   Reply With Quote Multi-Quote with this Post
Old 21-06-2012, 08:16 AM   #6
canuk7
Thanks to all for the replies.!!!
