27-01-2005, 06:57 PM | #1 | ||
Hi all,
if the weather holds out this sunday im off to eastern ck in my auto BA XR8, it will be my first attempt at grag racing ever and i just want some advice on: 1. how to launch? 2. how many revs? 3. best mode to do it in (4sp,3sp,ss mode)? 4. what pressure in tyres? And basicly anything you guys think i need to know. All help/advice appreciated Cheers Jim |
27-01-2005, 09:10 PM | #2 | ||
XB in parts...
Not that I have an auto but from what I read it'll do some good to get your stall speed worked out. Thats when you press the brake first and then the accelerator to the point just before the car starts to move forward. This gathers up the revs so when you let go of the brakes you have the car higher revving and hopefully closer to the power band to move off the line quicker.
Any of you auto drivers feel free to correct me on this. You may want to drop the pressure down on your tyres too. Don't have them running at street pressure. You can try combos of changing auto gears "manually" but I don't think it'll make that much a diff. I could be wrong. Experiment if you like. Don't run with a full tank of fuel. Try maybe a quarter to a half tank. I did 10+ runs (in a 6cyl tho) and never used a quarter of a tank. Try not to launch on the last light of the "tree". Theres so many tenths or hundredths of a second between each flash. Practice taking off on the second last light.... Like I said before there's plenty of others that have got this shit down pat so feel free to correct me if I've given any misguided advice. I'm still a noob myself.
Daily Driver 2019 Ford Escape...looking for XR6T's. |
27-01-2005, 09:11 PM | #3 | ||
XB in parts...
Oh and the best advice.
Have fun.
27-01-2005, 09:27 PM | #4 | |||
You probably wont do too well .. but it is a learning curve so don't sweat it if things don't go as you expect |
27-01-2005, 09:50 PM | #5 | ||
STi Pilot
I'm going to disagree with loxxr6 on a couple of things. (Sorry mate ;))
As it's your first time out don't worry about tyre pressures, or your reaction time. Everything else loxxr6 said I agree with. Leave your pressures as is. Work on getting the best launch rpm as you drive it off the street. That gives you a starting point, and as you get experience and get the feel for launching, then playing with pressures will make more sense to you. Reaction time doesn't affect your ET. As it's your first time out, take your time. Let the light go green, let the other guy zoom off down the track. Just concentrate on your launch RPM. If it takes you another 5 secs after the light goes green so be it. Take your time. Play with different stall speeds. Try launching at 1800rpm. Then increase it by maybe 50rpm each time, till you start losing traction. Compare your 60' times to each rpm to find your sweet spot. It's all about trial and error. The sweet spot will change once you play with pressures. The track 'stickiness' will also change from day to day. There's other variables that come into it also. Also, try to 'shallow stage'. That is, monitor your staging lights. (Two white lights atop the tree). As you creep onto the staging line the first light will glow. Now stop. Now, as slow as you can move forward till the next light also glows. STOP as soon as it lights up. Now you are (shallow) staged. Shallow staging will help you achieve a better ET, and better 60' time. You'll have that little extra speed before you break the beam and start the clock. Your reaction time will suffer, but that's not important, until you start bracket racing. Try to keep your staging as constant as possible. It's another variable that affects your 60' time, and as you want to concentrate on your launch rpm, which is indicated by your 60' time, you want your stage to be as constant as possible. With the auto, just keep it in performance mode. Has given me the best results with my car. Oh, and have fun ofcourse. : : |
27-01-2005, 09:58 PM | #6 | ||
STi Pilot
loxxr6, just have to comment on your ET...
14.68 is a great time for an AU XR6. Nice work!! :sm_headba But I think your mph is a bit off ;) |
28-01-2005, 06:54 PM | #7 | ||
3 Pedals R Better Than 2
And when you're are ready to decimate the dude in the next lane...........
Give it hell on the last yellow light. This will minimise reaction time and allow you to get the "hole shot" head start. ie: the car launches as the green light comes on. There's nothing better than racing a car bumper to bumper all the way to the line! |
28-01-2005, 06:58 PM | #8 | ||
my advice = take a mate + 1 camcorder and video it so you can watch it over and see what you can improve on.......and to show us here too of course.
28-01-2005, 07:52 PM | #9 | ||
Peter Car
I ran a 14.2 in my XR8 auto with nothing but a K&N filter. Just stall her up to 2500rpm and let her rip. I left it in performance mode and let it shift itself as it will always shift just before the rev limiter. Dropping tyre pressures to 20psi is ok and make sure you give it plenty of time with the bonnet up when you get there to let the engine bay cool a bit from the drive there.
28-01-2005, 10:05 PM | #10 | ||
Mate if i get anywhere near 14.2 id be over the moon, i cant wait!!!!!!
Cheers Jim |
29-01-2005, 12:06 AM | #11 | ||||
XB in parts...
29-01-2005, 09:32 AM | #12 | |||
29-01-2005, 11:12 AM | #13 | |||
STi Pilot
30-01-2005, 11:37 AM | #14 | ||
Cant believe this bloody rain! Anyway thanks for the advice guys ill have to use it next time.
Cheers Jim |
30-01-2005, 06:16 PM | #15 | ||
Giddy up.
I wouldn't shift the gear's untill you have other thing's down pat, just leave it in performance mode, as the rev's with the Boss motor come up to quick, ie 5800rpm, not like 7000rpm with the good ol windsor's/cleavland's.
