Old 26-02-2012, 11:19 AM   #1
REDAUXR6II
REDAUXR6II's Avatar
Default Starter motor bang
Hey All,
This morning I went out to start my XR and the battery was flat, so i followed the correct jump starting sequence as listed in the book and the it was still really sluggish to roll over groan groan groan tick tick tick.
so i left the 2 cars connected to charge the battery went to start it again and it let out a huge bang and an electrical smell from under the car.
I checked the dash and the lights were still on, i instantly thought computer but there was no electrical burnt smell in the car or near the computer and all the readings etc are comming up so that appears fine.
The car tries to start but only tick tick tick tick no cranking anymore.
Can i assume that my starter motor has for some reason blown up?
i checked the fuses but nothing has blown.
Why would the starter motor blow up?
REDAUXR6II is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2012, 07:50 PM   #2
mik
mik's Avatar
Default Re: Starter motor bang
i`d also check the wiring to the starter & battery cables for arcing , just in case there a loose connection , sometimes loose cables let of a bang until they weld themselves to the connection.
Old 07-03-2012, 07:23 AM   #3
REDAUXR6II
REDAUXR6II's Avatar
all sorted,
Turns out it was the battery that went bang, I measured the voltage on the battery and it was only 5 volts.
And when you try to draw to many amps from a battery that has none it can spark internally and ignite the hydrogen in the battery, I was lucky that nothing worse happened.
But the red beast lives again.
I did find out that the top bolt on the starter motor is easy as to get at from the top of the engine, so if you need to remove it try from the top side it made my life easier.
Old 08-03-2012, 09:40 AM   #4
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Good news. I was curious to see how this one panned out.
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is offline   Reply With Quote Multi-Quote with this Post
