Old 21-10-2011, 04:51 PM   #1
roadside
Exclamation crank but no start
hello all, stuck 200k from home,my old girl just turns over,but she will not start!,there,s 12 or so volts going to plug (TFI),with no spark @ end of leads going to spark plugs,? how do i test TFI ,distrib,or ? anything else I should test ,I have multimeter & test light,please help as need to get home.
roadside is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2011, 05:22 PM   #2
mik
mik's Avatar
Default Re: crank but no start
what sort of car /make and model is it???
Old 25-10-2011, 09:10 AM   #3
roadside
1990 ea falcon wag,cfi engine,it will start but only once in a blue moon,iam thinking maybe wiring ?
Old 25-10-2011, 09:36 AM   #4
ltd
Force Fed Fords
ltd's Avatar
Mate, could be a plethora of things.
Start simple, clean battery terminals, check earths are clean and tight, remove a plug and check for spark, should be nice and blue colour not orange (weak) spark.
If no spark then could be haul sensor; you'll need professional help for that.
Good luck
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2011, 09:58 AM   #5
outside
off in outer space
outside's Avatar
sounds like it maybe the coil
"Always be yourself... because the people that matter, don't mind and the people that do mind, don't matter".
outside is offline   Reply With Quote Multi-Quote with this Post
