Old 02-11-2005, 11:05 PM   #61
yobboford
locker king
yobboford's Avatar
i ran mine tonight and even when i had my last run at 9:50pm it was still 25 degree's with 80% humidity accorcing to the time slip....
couldnt even get near my PB, best was a 15.125, although my mph was 1 better, but did manage to get in 9 runs even though i didnt get there till 6.30pm.
EBII family wagon, 14.966 @ 90.86, 4lt 5-speed.
"WAGON MODS getting you to woolworths quicker!!!"
yobboford is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2005, 12:46 AM   #62
JC
JC's Avatar
Originally Posted by useless
02/99 may be something there. Guys I have just changed my speedo gear to black 23 tooth.My existing one was 21 tooth light green. The MAX ELLERYS manual is wrong.
Um I dont know how to say this but I took it for a spin up the road and wanted to see the rev limiter.I fanged it.My revs hit 6100-6200 rpm without anything that resembled a rev limiter.I am constantly getting 6000 rpm gear changes under heavy throttle.
Firstly how do I know I have hit the rev limiter? Secondly will I blow my engine with 6000 rpm gear changes?
You shouldn't - it's only a couple of hundred revs too high, and Ford would have built in a reasonable safety margin. In fact I think the BF 6 speeds allow a bit of over-rev, so it can't be too bad. But if you're revving that high, you are probably dropping out of the powerband anyway.
Ford Performance Club ACT
Old 03-11-2005, 04:30 PM   #63
Stav
Smile
Stav's Avatar
Ive been keeping an eye on air temperature here and when I get to run by 10 am the air temp based on the past few days will be around 30-34 degrees...
I actually took my car flat past 2nd to third for the first time today and it went to 6200 rpm and changed gear nicely.So I have a feeling AU 1 02 /99 may be a bit different.
My car is pulling well to 6000rpm with no power drop off noticed whatsoever.If it did I would install a grey speedo cog...the next one down.But as I mentioned it wants to keep going.Perhaps Ill upgrade the springs in future so that I can rev it higher.
Old 03-11-2005, 08:46 PM   #64
jonbays
TL40 Wagon?
useless i don't believe your tacho. I will bet its reading high.
you should get it checked who cares the black gear is good and it goes harder thats the point.
Stick it in first and rev slowly till you hit the rev limiter. now if your tachos not reading 5750 or thereabouts its wrong. the limit is hard coded in all the ecus 5800-5900 or thereabouts. not 6200
Old 03-11-2005, 08:57 PM   #65
jonbays
TL40 Wagon?
Just tested my speed limiter it still works!
The poor car is so modded it doesn't really know where it is but it in third it goes to 5600 rpm and then changes into fourth and stops.
My speedo says 197kmh but its reading high of course. Only doing 180 or thereabouts. either way not a big deal for a stret car that runs 145k on the strip anyway
Old 03-11-2005, 09:31 PM   #66
XR_Strider_GuY
Boss for Go, L98 for Show
Contributing Member
XR_Strider_GuY's Avatar
Couldn't agree more jonbays. An AU revs to 5750-5800rpm. In my case my XR's redline/cutout is at 5750rpm. Besides even with a dev 4 cam i highly doubt that max power will be any more than 5300rpm anyways.
Quote: Jeremy Clarkson "The fact of the matter is this, from just about any angle this is an impossibly pretty car"
XR_Strider_GuY is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2005, 09:46 PM   #67
Stav
Smile
Stav's Avatar
In first gear ..holding it it goes to 6100 rpm and hits the rev limiter.In auto mode I fang it ..it goes to 6000 rpm then changes gear...goes to 6200 rpm then changes gear again. I know your cars hit the limiter at the earlier speeds but mine does not.The AU 2 is quoted from factory to be a slower car than the au1.I believe that this and combined with a different speed gear to the au2 wagons indicates that the au 1 was definatley setup differently to au2.Even the coilpacks were different..
http://www.geocities.com/falconfacts...uiifalcon.html
http://www.geocities.com/falconfacts.../aufalcon.html
au2 vs au1.The au1 was quoted as being quicker.
Old 04-11-2005, 01:47 PM   #68
Casper
Contributing Member
Casper's Avatar
I have an AU1 Stav.. hard cutout on the revs is 5750... full stop. It was the same for ALL AU's. Either you have a weird ECU or your tacho is way out.
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2005, 07:53 PM   #69
Stav
Smile
Stav's Avatar
I think i may be wierd? py:
Old 04-11-2005, 08:26 PM   #70
Nik
i was just checking that site out useless has posted and is this a typo or what.
Engines:
4.0L Intech 6 cyl
Bore and stroke: 92 x 99 mm
Power: 157kW at 4900rpm
Torque: 357Nm at 3000rpm
Overhead camshaft, 2 valves per cylinder
Fuel system: EEC V fuel injection
Compression ratio: 9.6:1
4.0L Intech 6 cyl (XR6)
Bore and stroke: 93 x 99 mm
Power: 164kW at 5000rpm
Torque: 366Nm at 3150rpm
4.0L Intech VCT 6 cyl (Fairmont Ghia)
Power: 168kW at 5000rpm
Torque: 370Nm at 3500rpm
4.0L Intech VCT 6 cyl (XR6 VCT)
Power: 172kW at 5000rpm
Torque: 374Nm at 3500rpm
according to this the xr's had a 1mm bigger bore .
so whats the go is this true?
Old 05-11-2005, 08:04 AM   #71
Casper
Contributing Member
Casper's Avatar
Its a typo. Has to be. Given the Fairmont Ghia VCT and the XR6 VCT are IDENTICAL then there is no way there can be a bore difference.
