Old 13-01-2006, 10:02 PM   #1
tiger99
Question au fuel sender unit
I think it's dead as the tank is full and showing empty. any ideas on how to replace an au 99 sedan fuel sender unit. to be honest i havent checked the fuse, but i suspect its on the same as the instruments which are all working.
tiger99 is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2006, 08:59 AM   #2
64compact
lift up the boot mat and un do the plate above the tank. see if the wires are connected, you can check the connector wit a multi meter and see which one is the fuel pump and which one is the fuel guage, earth out the fuel guage one and the dash guage will read full if the guage is working ok then it is your sender. first before you pull it out get a "O" ring and a sender and have over 1/2 a tank of fuel in the tank to hold the bottom of the tank down far enough to refit the sender. cheers..
64compact is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2009, 11:54 AM   #3
jrh001
Default 1999 AU fuel sender
Originally Posted by 64compact
lift up the boot mat and un do the plate above the tank. ...
Hi,
How to undo the plate above the tank? Is it pushed in, screwed in or glued in? (My fuel gauge is reading "high" - shows half when almost empty - although the DTE display seems correct)
JohnH
jrh001 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2009, 11:01 AM   #4
jrh001
Originally Posted by jrh001
Hi,
JohnH
Answer is: The plate is glued in very tightly.
Problem appears to be the fuel gauge. I'm told that the entire cluster has to be replaced. Replacement (from wreckers) may have higher odometer reading :(
Old 15-10-2009, 12:07 PM   #5
KR1STO
Just another mock-up..
KR1STO's Avatar
or lower... you can find some good low kms clusters around..
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2009, 01:04 PM   #6
jrh001
Is it easy to replace the dash cluster? (Searched but couldn't find any threads.)
JH
Old 15-10-2009, 01:16 PM   #7
BIGJB
BIGJB's Avatar
Easy as. 2 plastic grommets covering screws at top of dash cluster.
Remove them then the screws behind them and the cluster just slides out.
Just a matter of unplugging the looms in the back and it's out.
5 Min job tops.
BIGJB is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2009, 05:06 PM   #8
Damozxr6
FORD4LIFE
Damozxr6's Avatar
my ute has fuel sender probs. after driving a few kms it works its self out and reads full again. kinda use to it now.
oneday ill replace it lmao.
:evil3: AUII XR8 UTE. BLACK. MANUAL :
: out: HSV " I DONT WANT ONE" :monkes:
Damozxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2009, 06:56 PM   #9
jrh001
5 Min job tops.
Thanks for the info.
Is there a way to test the sender (eg with a multimeter)?
I've been quoted $110 for an instrument cluster from a Ford wreckers/spares place in Springvale. Any other recommendations where to shop for one? (Melb SE suburbs).
JH
Old 09-07-2011, 08:02 AM   #10
ramsrider17
Default Re: au fuel sender unit
I have a auII ute and it does the same thing. on a highway it works but as soon as i start stopping and starting it changes from full to empty every minute lol i just go 500km then fill up.
ramsrider17 is offline   Reply With Quote Multi-Quote with this Post
