01-07-2011, 11:12 AM | #61 | ||
not hard to check your brake lights i look in the mirror to see them light up any nearby object day or night before every drive but in saying that still had the switch die between home and adelaide one trip only found out when i put a trailer on and re checked them.
01-07-2011, 12:47 PM | #62 | |||
I know! We actually got off our a$res, got proactive and took responsibility for checks and preventive maintenance at a more personal level instead of replying on some little bulb to tell an individual if something "may have" failed or a service is now due or the engine requires oil cause the service indicator lamp failed which, in turn, obvisously didn't tell the operator the car is due for service cause one does not have the common sense to work out for ones self when it is due cause once again, we reply on a little light telling us so. P.S. : I recieved your PM. Not once did I say "that the sensors and warning systems are not a good idea". I said they fail and not to be fully relied upon. They do give incorrect readings, even if no warnings appears. Last edited by J.C.; 01-07-2011 at 12:56 PM. |
01-07-2011, 01:10 PM | #63 | ||
wow.. so upset about ****y little light bulbs.... some need to chill tfo......
01-07-2011, 01:35 PM | #64 | |||
Ich bin ein auslander
By the way, you are welcome, it was no problem for me to admit I was wrong on a certain element of my previous posts as I stated in my PM. It is a shame you have not been able to do the same, but I guess the final line of your signature explains why.
Growing old is compulsory, growing up is optional! |
01-07-2011, 01:39 PM | #65 | |||
By the way, I have also on many occasions informed someone of a fault on their car and my efforts are often well received (sometimes not but not to worry). I even had to get the attention of a lady on the motorway once and get her to pull over so I could warn her that she had a fire under her bonnet. I also used the ambulance fire extinguisher to put it out for her.
01-07-2011, 01:39 PM | #66 | |||
Yeah that's not a knobby response at all now is it.. I personally don't tell people, purely because the reply I used to get when I did wasn't exactly a nice one.
flickr |
01-07-2011, 01:47 PM | #67 | ||
^^^^^^ And what value does your comment hold Sarge?
01-07-2011, 01:51 PM | #68 | ||
Long live the Falcon GT
Why don't we all just get into the habit of doing a walk around the car prior to getting in...
Didn't anyone play Police Quest when they were younger??? (if you didn't do a walk around before getting in the car - BOOM)....
02-07-2011, 05:07 AM | #69 | ||||
rather than lay blame on them why not look at what YOU could have done to reduce your risks and consider that next time you drive. please dont feel like im attacing you, that is not my intention. most of us learn from our experiences. questions is, what are you going to learn from this event Quote:
02-07-2011, 10:44 AM | #70 | |||
Fixing Ford's **** ups
There are many cars these days fitted with tyre pressure sensors, however the cars fitted with these are generally fitted with low profile tyres and the cars are either of the higher pricing scale, or are European cars The sensors average out at $300 each sensor and they are very easily damaged. Now don't think I'm denying it's not a good idea, I'm mearly pointing out costing of them and the cars I see with them fitted
02-07-2011, 10:51 AM | #71 | |||
Very easy to do, IF you have something to have the lights reflect off. I don't have a roller door, nor can I get the cars close enough to the house to get the light reflection off it. I have to rely on the weekend, for the misses to be home, so there are 2 of us to do the brake light check. The other light checks don't need 2 people, so that's not a problem.
02-07-2011, 11:04 AM | #72 | |||
moderator ford coupe club
02-07-2011, 11:24 AM | #73 | ||
Just thinking outside the box here.
How does something like a brick, paver or piece of timber on the brake pedal sound to anyone wishing to check their brake lights and they happen to be on their own? Just the slightest depression on the pedal activates the switch so you don't need anything all that heavy. A 12inch shifter probably do the trick. Just a thought. |
02-07-2011, 11:57 AM | #74 | |||
02-07-2011, 11:58 AM | #75 | |||
I am going to challenge the idea of getting everyone to do that every day though, it will never happen.
02-07-2011, 12:21 PM | #76 | |||
It's still operating via a sensor. Some have the sensor in the wheel itself some via the braking system. The can still be easily damaged and the cost of the sensor varies depending on the car. My quoting was a general overview, as I wasn't wasting 6 pages going through each and every car fitted with them, where they were fitted and the cost of replacement of them. There is also an aftermarket system available, where by the sensor is the valve cap and sends a signal to a devise inside the car and reads the pressure. (Tyre dog is the name). The problem with that system is, little mongrels that nick valve caps, means you have to buy a complete new system @ $400 to $500 a pop. I have also seen valve caps that are preset to 32 to 34 PSI. These show a green piece when the pressure is at this maximum pressure. This green section disappears if the pressure drops below that, but that system requires you to actually look at the valve cap. Again, little mongrel kids can pinch them. There are also valve caps for truck tyres. These are preset to work between 70 and 130 PSI. Once the pressure drops below 70 PSI, it has a little red led light that flashes continuiously until you pump it back upto the right pressure. Again, this requires you to actually look at the valve cap and little mongrel kids can pinch them. So there are various systems around, but the cost and how they work vary.
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone Last edited by svo supporter; 02-07-2011 at 12:36 PM. |
02-07-2011, 12:25 PM | #77 | |||
Come to think of it, now you've mentioned it. There are other cars of this era that did the same thing. So maybe it was the "start" of the modern era of self checking.
02-07-2011, 01:44 PM | #78 | ||
Any car will change the rate of the indicator flash if a globe blows. A bulb is a resistor, the indicator flasher unit is a bimetalic strip that bends when it heats during current flow. If your lose a resistor (the bulb) from the circuit, less resistance = more current flow. This increase in current flow increases the heat through the bimetalic strip so the indicators flash faster.
Try it out, pull out one globe and your indicators will flash faster, replace the globe and they return to normal. It is the one sure fire way I know an indicator bulb is blown on my own vehicles and the work ones.
02-07-2011, 02:03 PM | #79 | |||
And trust me, considering I rotate the wheels on my cars every 5000 km I have seen the hubs enough to know there are no extra sensors there. Here is a picture to prove it http://www.realoem.com/bmw/showparts...76&hg=31&fg=10
02-07-2011, 04:02 PM | #80 | ||
Rob
The Outsider - ryanstev said in his original post that he 'almost' hit someone, so i would argue that he was driving to the conditions and did have enough of a gap otherwise there would've been a collision. not sure why you are suggesting otherwise.
02-07-2011, 07:28 PM | #81 | |||
Break a factory sensor, it'll cost round about $300 each to replace. (Give or take a few hundred depending on the car). Doesn't matter if the sensor is in the rim, or in the ABS system.
02-07-2011, 07:33 PM | #82 | ||
I once had a couple of burly maori blokes pull up beside me in a commodore. I got nervous as they winded down the window to speak to me. I braced myself for hospitalisation (for something I was desperately trying to figure out) when they kindly told me my fuel flap was open.
So after soiling myself I thanked them. Just goes to show.... |
02-07-2011, 08:43 PM | #83 | |||
That is true, but they are there so why not use them for that other function. Because they are already there using for that extra and very useful function (it really does work at detecting a soft tyre), most cars have ABS, they have those sensors anyway so it is no extra equipment to break is it? I do see your point but to me that is like saying I am not going to have air conditioning in the car because it might break and then it will cost me money. The similes to this line of thought are endless.
02-07-2011, 10:48 PM | #84 | |||
Mate, the sensors work from the wheels. Be it inside the rim or outside. So in short they can be broken, which in turn can cost a few bucks. So instead of going along these lines, why not go back to the topic at hand
02-07-2011, 11:04 PM | #85 | ||
Yeah whatever
03-07-2011, 03:48 AM | #86 | |||
my bad, seems like your right. either way, blaming someone else for something that you should be in control of is poor form ill go back and edit my post so others dont get the wrong idea EDIT: seems like i cant go back and edit my post anymore. rayn sorry for thinking you actually hit the car but i still stand by my comments regarding leaving a safe gap |
03-07-2011, 08:16 AM | #87 | |||
therefore if another safety feature can be built into the same sensor, without putting anymore risk into the sensor, then that is a good thing |
