Old 12-10-2005, 01:47 AM   #1
wynode
wynode's Avatar
Default New to the forums from a slightly different angle ;)
Just thought i'd say hello as the parents little AU Fairmont has past its extended warranty period and now I get to save the olds some money.......errr I meant do the servicing.
Gotta admit I was pretty shocked at the costs of the servicing at our local Ford dealership but that was part of the agreement for the extended warranty. I've had a browse around here and there seems to be some good information.
I actually run a Honda forum over at www.ozhonda.com so know what it takes to have good articles that people can read.
Keep up the good work!
wynode is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2005, 02:10 AM   #2
BlackLS
Welcome!
Hope to see you a lot more on the board. Where are you located?
Old 12-10-2005, 02:11 AM   #3
Grechie
Grechie's Avatar
welcome wynode, and i hope u enjoy ur stay
2015 FGX XR8 - 557rwkw on E85
KPM Street Fighter
PCMTec
Michelin Pilot Sport Cup 2 - 255/35/19 - 275/35/19
Shockworks Coilovers
PITLANE AUTOMOTIVE & PERFORMANCE
Grechie is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2005, 02:22 AM   #4
wynode
wynode's Avatar
Thanks ArgonEF. I'm in NW Sydney. I'm also actually moving away from home soon so hopefully the family doesn't have too many hassles with the car!
I've worked on Honda's quite a bit so I would have looked forward to using this site a bit more and working a bit on the Ford!
Old 12-10-2005, 06:04 AM   #5
bindi
Redhead extraordinaire...
bindi's Avatar
Welcome... it's addictive (ffs, I'm here and it's only 6am - see what I mean?!).
Have fun! :eclipsee_
Bindi
88 EA- his car
88 Rolla - MY car
Originally Posted by big_waity
Oh, and another surefire symptom will be the Falcon badge at the back.
bindi is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2005, 07:26 AM   #6
LTDHO
The one and only
LTDHO's Avatar
Welcome to the forums!
Also, don't go to Ford for servicing unless you like paying alot for nothing. You will find someone cheaper and better!
Tuned by CVE Performance
Old 12-10-2005, 09:38 AM   #7
BlackLS
You'll find if you can work on Hondas good, the Ford will be **** easy. Recon you could pull the head off to do a head gasket? That would probably be the hardest (most expensive) thing you would have to work on in the Ford. If so then you can save packets.
Old 12-10-2005, 11:23 AM   #8
wynode
wynode's Avatar
Well i've swaped out an engine and changed gearbox bearings in a Honda so hopefully the Ford won't be too bad Thanks for the welcome guys!
