Old 21-02-2011, 10:11 AM   #1
james22
With da Warlords
james22's Avatar
Default Clockspring Advice...
Hi All.
Lent my car to my old man on the weekend. Anyway I noticed this morning when reversing out of the garage, that the steering wheel is making a clicking noise when turning.
I suspect it could be the clockspring (and I have had intermittant faults with my airbag light lately too).
Does this sound right? and what is involved in replacing it...
Cheers.
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2011, 05:23 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
clockspring is fairly easy to replace - just need to take the airbag off iirc?
also check it's not just your cowling around your steering column...
Old 21-02-2011, 06:09 PM   #3
kenz
BOSS Pilot
kenz's Avatar
Mine has recently started clicking aswell in my Ba xr8. If I move the wheel barely to one side it will click and then click again on the way back. If its a similar setup to the BAs they are pretty easy to get apart just pull the airbag and steering wheel off and thats about the bulk of it. I had mine off about 6months ago and it was fine when I put it back together and then started clicking only about 2months ago
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
