Old 16-02-2011, 05:44 PM   #1
ic0nic
Default Idle problems solved! Thank you!
Just wanted to say thank you to all of those that posted on these forums in relation to idle issues. I just spend all of four hours replacing my inlet manifold gasket and this solved the problem!
Thank you!
ic0nic is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2011, 06:44 PM   #2
sly
Sly like a G6
sly's Avatar
Yep, it'll do the trick. Apparently it's common for the gasket to leak around cyls 1 & 2, but mine was leaking at the back, around 5 &6.
Now I have a sweet, smooth idle down to 600rpm that is only belied by some slight whine from the blower :-)
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2011, 07:01 PM   #3
Good news.
aussiblue is online now   Reply With Quote Multi-Quote with this Post
