Old 21-01-2011, 02:46 PM   #1
pwr4ce
pwr4ce's Avatar
Default Replacing Heater Knob on AUIII XR8
I posted this in the Tech section a couple of weeks ago - without response:
Can anyone tell me how to go about removing the Heater Fan control Knob on a AUIII XR8.
The knob I have to replace it with has a lip on the end that will seem to lock into place when installed. My problem is removing the old one to replace it with the new one.
Do I need to remove the trim panels around the radio/ Heater controls to do this?
MY18 Mustang GT
MY18 Everest Trend
Harley Davidson FXBRS
pwr4ce is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2011, 02:50 PM   #2
b2tf
not here much anymore
b2tf's Avatar
Yes
headunit out
find all philips head screws in dash and undo
then pull the fascia off
the heater controls then screw into that from the back so you can undo those screws, and then access the knobs.
2024 F150 XLT
Old 21-01-2011, 03:00 PM   #3
pwr4ce
pwr4ce's Avatar
Originally Posted by b2tf
Yes
headunit out
Great - thanks very much for answering this.
I guess Ill set aside a couple of hours to do it
MY18 Mustang GT
MY18 Everest Trend
Old 21-01-2011, 03:00 PM   #4
james22
With da Warlords
james22's Avatar
^^^ As he said. Just be careful when pulling the fascia off, that you don't break any of the clips (or bloody cut yourself on the sharp edge like i do lol)
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2011, 03:03 PM   #5
b2tf
b2tf's Avatar
The trickiest bit is getting the factory headunit out - $#&&% of a job.
It is fairly straight forward after that, I cant remember the location of all of the screws once you get the HU out but just have a good look around and you will find them. After that you should be able to firmly pull off the outer surround and access the AC controls, you will likely need to unplug all the looms etc to be able to take it out and work on it. Dont worry about that bit though because all of the plugs are different, so you cant plug them into the wrong spot (different sizes etc).
2024 F150 XLT
Old 21-01-2011, 03:03 PM   #6
b2tf
b2tf's Avatar
ya big shirley
2024 F150 XLT
