Old 15-01-2011, 07:53 PM   #1
cobbadan
cobbadan's Avatar
Default Flooded parts - can they be saved ??
Ive got/had parts stored at my brothers workshop at rocklea in brisbane.
The workshop got about 4 metres of water through it and everything is covered in mud n silt and god knows what else. Its a hell of a clean up job.
The least of my concerns at the moment but i thought id ask peoples opinions
parts are from a stock xr6 turbo
Turbo
complete intake manifold with throttle body
exhaust manifold & dump pipe
complete exhaust system
intercooler
all the piping and airbox should be fine.
The turbo i expect to be a throw away
exhaust manifold and dump pipe will be fine i assume.
The exhaust system -- whats ya thoughts ?
It will be thoroughly rinsed out with clean water but i would expect the mufflers and cat to be a problem.
07 BF II XR6 - 6 spd auto
Colour = Dejavu Mica
Have a look
They are great cars but the build quality is crap
cobbadan is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2011, 08:01 PM   #2
The G6ET Spot
The exhaust will definitely be a throw away, as you will never get all the silt out of the fibreglass packing in the mufflers. You could just cut the mufflers out and keep the pipes though.
The turbo should be OK though, just need to be stripped, cleaned and replace bearings..
The G6ET Spot is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2011, 08:40 PM   #3
cobbadan
cobbadan's Avatar
exhaust system gone, still hope for the turbo. Thats good to hear
Have a look
Old 16-01-2011, 11:06 AM   #4
Kingsley
As it's been said, the turbo should have a rebuild, but the pipes and mufflers are easily enough replaced. Throw them out.
It'll be interesting to see what pops up on eBay in the next few months from up in flood affected area's and how badly damaged they are.
Kingsley is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2011, 11:20 AM   #5
Herrod Motorsport
www.sctflashtuning.com
Herrod Motorsport's Avatar
saturate everything with WD40
Australia's No1 Ford Enhancement Specialist
103 Northgate Drive
Thomastown
VIC 3074
Phone: 03 9464 5100
Fax: 03 9464 5166
Herrod Motorsport is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2011, 12:48 PM   #6
cobbadan
cobbadan's Avatar
Roger that - will do
Have a look
Old 16-01-2011, 01:00 PM   #7
Sizey
Mk5 Transbulance
Some throttle body cleaner will do some good on all bits. Turbo will need to be dismantled to asses damage however another build (inc bearings etc) of the turbo will more than likely be needed.
The exhaust needs to be filed under B
DOING THE UNDO-ABLE
B series xr6 wagon
Now deceased
BF Fairlane ex taxi
Now for more fun
[/CENTER]
Sizey is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2011, 08:01 PM   #8
ebxr8240
Performance moderator
ebxr8240's Avatar
To overhaul one of these turbo's would nearly cost as much as new one..
They have seals etc in them which hold 60+ Lb oil pressure at 1200*+ with all the exhaust rubbish.. I would just disassemble both turbine / compressor housings carefully spray with WD40 etc wipe clean or blow out with compressed air..
If the silt hasn't dried out yet it's usually easy to clean out with fresh water...
That's if what ever your cleaning can take water !!!
Add some fresh oil to the CRA before use...
Daily driver GTE FG..
Old 16-01-2011, 08:02 PM   #9
ebxr8240
ebxr8240's Avatar
If the silt hasn't dried out yet? It's usually easy to clean out with fresh water...
Old 16-01-2011, 09:26 PM   #10
cobbadan
cobbadan's Avatar
thanks for the advice
Have a look
Old 17-01-2011, 11:06 AM   #11
aussie muscle
aussie muscle's Avatar
my brother bought a VC Valiant (1967) that had been submerged in the Nyngan floods in the early 90s. i pulled the heads off and cleaned out the gunk in the cylinders and cleaned everything in the engine and it fired up and ran for 4 more years. it was still going when he sold it. we just replaced anything that could be affected by water, eg filters, etc.
there was a watermark inside the car... at the top of the windows (permanently marked the headliner running down the rear pillar)
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2011, 12:25 PM   #12
Kingsley
Same thing happened here after the Newcastle floods a few years back. The insurance companies banded togather and held a auction of all the damaged vehicles near the docks. They sold plenty.
