Old 09-01-2011, 06:50 PM   #1
bodhisattva
Default au3 overheats and misses
Hello, I have an AU Series 3 auto standard six cylinder, petrol, no mods, 178K, and it's generally good except for a few annoying things which someone may be able to help with please.
1. It seems to overheat easily – not while driving, the temp gauge never goes above between the N and the O in NORMAL, but I notice that when I stop my car after going up my long and steep driveway, the coolant overflow often boils and bubbles, and sometimes overflows, or at the very least I can often smell the hot coolant vapours. I notice that the radiator fans don't seem to stay switched on when I turn the engine off, which I would have thought they should if the radiator/engine is hot (all the other car makes I've had do this). I took it to an auto electrician and we checked the fuses and they looked okay, and when the engine is running he said the fans were working (he used a torch to see in the back of the fan shrouds) so how come the coolant overflows or bubbles and the fans don't stay on when the engine is off to cool it down? The car has been serviced regularly since new and the coolant appears nice and green and clean etc, although I haven't had it flushed yet. Any ideas please? Why does the engine seem to run so hot?
2. Second problem is a miss that comes and goes intermittently, but mainly seems to happen when engine is warm/hot. I don't know if it's related to the problem in 1. above? It's not major banging and coughing, but enough so that I can feel it, but only when the engine is under reasonable load like going up reasonable hills. When it's not missing (not often) it will go up a particular hill in Drive in Economy mode towing a trailer at 100kph easily; when it's missing, I have to drop it back to 3rd in power mode to reach 90kph with no trailer! So here's what I've done so far: changed all the plugs to Iridium ones, got a mechanic to check on oscilloscope for signs of plug lead shorting etc (no signs of that), changed air cleaner, ran fuel injector cleaner through the tank (seemed to make a small difference for a while) and then the big one – changed the fuel filter. The filter was full of jet black grunge that looked like used sump oil. With the new fuel filter the car ran brilliantly for a few days, then the misfire returned. So, my theory is that more grunge might have been introduced from the tank into the new filter, so I'm having that changed again this week and we'll see what colour the petrol looks like this time. If it's black again, then we have to suspect a load of dirty fuel in the tank, and will probably need to flush the fuel tank. If filter seems fine, then then I'll have a new filter again anyway, and the problem will have to be looked for elsewhere. Any ideas on this one also please? Many thanks.
bodhisattva is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2011, 06:55 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
1. Falcon thermo fans don't stay on after you turn the car off even if you've cooked it. Don't trust guages, perhaps get a thermometer.
2. Gooped up fuel filters are usually a sign of a problem upstream. Possibly new fuel pump time.
Old 09-01-2011, 07:00 PM   #3
bodhisattva
Thanks. How would a problem with the fuel pump clag up the fuel filter? I know the previous owners used to go away on caravan trips, and I assumed they may have picked up a load of dirty fuel somewhere in the country... hence the clogged fuel filter.
Old 09-01-2011, 07:32 PM   #4
BuckTooth
Feel the boost
BuckTooth's Avatar
1. I would look at replacing your radiator cap soon. Explains the reason for the coolant loss after letting the car sit.
2. Sadly i cannot help with.
2005 BA Mk2 XR8 ...... Let the fun begin
Drive carefully! Remember, it's not only a car that can be recalled by it's maker.
BuckTooth is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2011, 08:26 PM   #5
EvilChief
Boost Addict
both those symtoms put together point towards blown headgasket (coolant jacket to cylinder, the kms on the engine are about right too. Check spark plugs and compression test.
EDIT: Symptom 2 can also be caused by stuffed intake manifold gasket
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2011, 01:12 AM   #6
mik
mik's Avatar
the head gasget thing i was also thinking of, a good tune up place or a cooling system /radiator repair place can check for head gasget pretty easy, the goopy fuel filter is a bit of worry too, good luck with it.
Old 10-01-2011, 08:22 AM   #7
bodhisattva
Thanks guys. I'd thought of the head gasket too as a possibility, but was going down the fuel filter path as a less expensive alternative first... But I'll add the compression test to the fuel filter check this Friday, and see what we come up with. Hope it's not the head gasket, as that will be big bucks I assume...
