Old 06-01-2011, 06:27 PM   #1
4ford
Default Series 2/3 PBR Front Brake calipers
Guys...
I recently changed my S2 sedan brake master cylinder for a replacement new item (easiest replacement m/cylinder job I've ever done!), because of ongoing front brake heating problems.
Well, that wasn't the whole problem, both front brakes were also dragging, which was why I changed the m/cylinder in the first place.
Thinking the problem was then the slides binding, I removed both front calipers, only to find one of the pistons in each caliper was frozen, guess I should have checked first! (Well done that man with that advise I should have taken!).
Anyway, the point of all this is, after phoning around looking for some recon calipers, and not locating any, I called my local Repco branch to see what they had...well, surprisingly the guy there said they had some (a pair) of suitable calipers, brand new PBR ones, that were going out for.....$25 each side!!! (Yes that's right..just $25 per side, brand new, some sort of 'clearance' deal!)
Needless to say, I got down there asap!
So, if you're in the market, or will be soon, it may pay to check with your local Repco branch, because they are normally around $175 each side.
Yep, I got 'em home and they look great, although I will need to transfer over my original slides, so I also got some rubber lube and replacement crush washers for the hose connections, amounting to around $6!
A good day for bargains...check 'em out!
Now all I have to done is fit them tomorrow!
4ford is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2011, 08:17 PM   #2
mik
mik's Avatar
well done mate, its not often you get a bargain like that.
Old 06-01-2011, 09:29 PM   #3
Boza
Boza's Avatar
damn thats cheap
Boza is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2011, 09:42 PM   #4
JC
JC's Avatar
Originally Posted by 4ford
Guys...
Glad that worked out well - the cost of the callipers is less than the calliper kit (but you already knwo that)!
Well done on a good deal - let us know how your brakes are now that they are effectively all new.
Ford Performance Club ACT
Old 06-01-2011, 10:23 PM   #5
private9
www.TUFFCARPARTS.com
private9's Avatar
That's a killer deal, well done!
private9 is offline   Reply With Quote Multi-Quote with this Post
