Closed Thread
Old 03-01-2011, 01:13 PM   #1
dags
Default Hi Idle in BA
Has any one had a BA turbo idle at 1400 rpm and wont go below
dags is offline
Old 03-01-2011, 05:37 PM   #2
jixel 78
Chances are its got an air leak on the inlet side most probably from a broken pcv valve or being a trbo possibly a split or loose intake gasket, these are the basics, an electronic issue may be present too, although usually if the throttle body/accellerator pedal system has an issue, it will bring on the engine light and switch to a `guard mode` with limited throttle control. They are common for broken PCV valves, theyre pushed into a grommet at the rear of the rocker cover, but it may have blown the pcv pipe off under the throttle body, have a good look/listen around the throttle with the engine running you`ll probably hear it hissing its tits off.
XC GXL Warm 351c AOD
09 VE SV6 Sportwagon
BA Fairmont Ghia
jixel 78 is offline
Old 03-01-2011, 06:01 PM   #3
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
http://fordforums.com.au/showthread.php?t=11318447
Falcon Coupe is offline
Closed Thread
