Old 13-12-2010, 11:51 AM   #1
63futura
63futura's Avatar
Default Battery in boot
Does anyone know the rule for the battery being in the boot for drag racing ?
Have been told i cant just use the plastic box that its in and that i have to secure it with a metal bracket
63futura is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2010, 05:49 PM   #2
naughts
Hmmmmm Mulberry....
naughts's Avatar
Correct. Must have a bracket.
naughts is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2010, 06:19 PM   #3
63futura
63futura's Avatar
So could i just use the same bracket thats used when its in the engine bay ?
Like this
Old 13-12-2010, 09:53 PM   #4
Ivan
Like this
Yes but everytime you get scrutineered they will make you take the top off the box to prove it is securely bolted.
Ian
Ivan is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2010, 10:01 PM   #5
tex
Broken
tex's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: With the exception of maybe HSE2, nobody writes a review like Texy.
Like this
Hmmmm, that looks familiar....
The Scud GT
11.4 @ 128, 1.88 60ft.
tex is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2010, 10:12 PM   #6
naughts
Hmmmmm Mulberry....
naughts's Avatar
Ian
I dont bother having a lid anymore
Old 15-12-2010, 11:36 AM   #7
63futura
63futura's Avatar
Do you have to have an isolater switch aswell ?
Old 15-12-2010, 03:52 PM   #8
redxm
64 Deluxe 4 door
redxm's Avatar
Im pretty sure you will need to seal the panel behind the rear seat, to create a firewall.
XM Deluxe
FG XR50
BA Pursuit Ute
redxm is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2010, 05:41 PM   #9
xagsjoe
Patience is a virtue
xagsjoe's Avatar
You only need a firewall if you have a fuel cell in the boot, and yes mate you must have an isolator if the battery is moved from it's standard location.
It must also cut the engine and all power when off. Basicly the charge wire has to go to the +ve on the battery and you pull power for the car from the switched side of the isolator not from +ve on the battery.
417ci CHI headed XD.
Dynamic transmissions C4
Track times
60ft pb 1.365 (24-3-12)
10.173 @ 134.97mph 1/4
6.324 @ 108.93mph 1/8th PB
SOLD
xagsjoe is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2010, 06:58 PM   #10
redxm
64 Deluxe 4 door
redxm's Avatar
Interesting.... circuit racing you must have firewall if battery is in the boot. Learn something every day
XM Deluxe
FG XR50
BA Pursuit Ute
Old 16-12-2010, 12:51 PM   #11
63futura
63futura's Avatar
Ok
So i do have a fuel cell in the boot and the battery in the boot but all fuel lines are under the car (like a drop tank setup )
So i need to close in behind the back seat to make a firewall (can i use alloy)
and need to fit isolator ?
Where does the isolator go ? ie outside the car or in the boot or in the car
Is there an Andra book for all this stuff ?
Thanks for any help
Old 16-12-2010, 05:21 PM   #12
naughts
Hmmmmm Mulberry....
naughts's Avatar
PM sent
Old 17-12-2010, 01:59 PM   #13
63futura
63futura's Avatar
PM sent
All sorted
Thanks Naughts
