Old 24-09-2010, 03:43 PM   #1
mrbaxr6t
mrbaxr6t's Avatar
Default Jumpstarting LV XR5
well if this experience is anything to go by DONT DO IT heres why :
Lady whom frequents my wifes work (petrol station) has an XR5T as a fleet car, it is hers for full use and has company signage enblazoned on it - anyway she got stuck at night as the XR5 wouldn't crank (flat battery) so she had a good Samaritan jump start the car, this is where the story gets a little sketchy but the car spent 4 weeks at the Ford dealership with them trying to fix the car, I suspect it has blown the brains out of the ECU the dealer did get it going again but by her own admission the cars just not the same anymore and she is gutted, but takes heart in the fact she only has it for another 5,000 before it gets swapped for a new car again, I am posting this here to make other owners aware of the possible consequences of jump starting an XR5
Phantom, T56, leather and sunroof BAmk1 :yeees:
Holden special vehicles - for special people
mrbaxr6t is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2010, 09:19 AM   #2
20focus05
I wanna XR5
20focus05's Avatar
it has always been that you have to be careful jump starting any efi/computerized car.
one thing that can help is to turn on lights, fan etc of going car while connecting to minimize voltage spikes.
Or use anti spike jumperleads.
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2010, 12:38 PM   #3
bseos
bseos's Avatar
could the same thing happen if the situation was reversed? Say the xr5 giving the other car a jump start?
Last time i told someone this, they just laughed it off.. But what i found funny was those douchs were trying to jump start a manual car.
2007 LT Focus Zetec Hatch
-Lowered on King Springs Super Lows 50mm
-20% Tinted Windows All Round
-K&N Pod Filter
-XR5 Rims (Late Model)
bseos is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2010, 02:44 PM   #4
ptwhite2003
Default Jumpstart a manual car
Nothing wrong with jumpstarting a manual. Sometimes you're in the wrong place, like at the bottom of a hill instead of the top, or you're surrounded by pensioners who can't help you push start it.
ptwhite2003 is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2010, 05:10 PM   #5
DJM83
Barra Turbo > V8
DJM83's Avatar
IIRC coerrectly if starting an EFI car one of the leads should be on an earth point ie engine block, sounds like it had both leads on both terminals of battery. That said i wont be using leads to start my XR5.
Was it an LV? If yes sure it wasnt the passive key gone flat?
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
-2022 Hyundai Tucson Highlander Diesel N Line
Old 26-09-2010, 04:03 PM   #6
mrbaxr6t
mrbaxr6t's Avatar
YES it was an LV and YES they jumped it as it for some reason just didn't want to start, they somehow got it to go and in the process poleaxed the car, I have been meaning to talk to the owner personally to see if i can reveal more details as what was wrong what they did and what was the result (in terms of damage done) I posted initially to highlight there is a risk involved in jumpstarting an LV XR5 there is so few of them already around, why kill them off through ignorance?
Old 26-09-2010, 04:13 PM   #7
DJM83
Barra Turbo > V8
DJM83's Avatar
I wasnt having a go i was merely asking some questions so settle down.
I havnt read my manual re the topic so dont know if you can actually use leads to start these. Ive seen numrous late model cars started with leads i used my old TE50 to start other EFI cars so i dont know what may have happened in this case
Old 26-09-2010, 05:13 PM   #8
mrbaxr6t
mrbaxr6t's Avatar
I didn't think you were having a go I was just trying to answer your questions the best way I could but at this time I don't know what exactly happened apart from the fact it was jumpstarted and in doing so it was heavily damaged and even though it is going again is still not right, is a shame is all and I would hate to see more nice cars ruined because of simple things like this
Old 27-09-2010, 11:12 AM   #9
entheos
There are special Jumper leads on the market with filters/capacitors/something in-line to avoid the surging that can cause ECU overload. I personally would walk home (irrespective of how far it was) before i jump started any car these days without a set of these leads...Or there are those special jump start things you can buy for similar price to the good jumper leads
Regardless, I would always jump a car positive terminal to positive terminal and negative terminal of the donor car to the chassis of the car receiving the jump start....
I think what DJM might've been getting at is that if the battery in the keyfob, or even the receiver is having issues 'connecting' with the key, then you can hold the fob up close to where the ignition barrel would normally be. There is a cap over a small slot there which you can place the little mini key in to start the car if this is the case. If it truely was a flat battery that sucks, but these are the things that you learn over time about the little quirks of keyless start.
Groomy
Sinclair Ford - Sydney
entheos is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2010, 09:35 AM   #10
mrbaxr6t
mrbaxr6t's Avatar
I had a very brief conversation with the owner she tells me the car had its headlights/foglights left on all night, I tried this and apart from it beeping its head off it drops the headlights down to parkers when the engines off, not sure of the foglights remain on with the parkers when they auto drop down, when she tried to start it the interior lights went out when the starter motor attempted to crank (I am assuming here womans not really a gearhead) given that the car had its lights left on all night the assumption was flat underbonnet battery so she got it jumpstarted I don't know how the leads were connected as "some guy" did it for her the leads were connected the XR5 cranked and started at which time the guy removed the leads and it "stopped" she then cranked it unassisted and it started but was extremely unhappy ***** idle no power screen indash gone haywire so thats when she took it to Ford, sadly this is where the conversation ended as she was in a hurry, I thanked her for her time and let her on her way.
