24-08-2010, 09:34 PM | #31 | ||
Lookin good.............bitchinnnn!!!
AZZA
1967 XR Falcon Wagon, Super Pursuit…….for now. *****XR PARTS WANTED******* |
25-08-2010, 11:35 AM | #32 | ||
AFF Whore
Agreed with The Monty, give it a month, mine weren't that great (SL's) but after a month they sat pretty much level on the tyre. Glad I didn't go SSL's as my diff has already been used as an excavation tool on some nasty ungraded dirt roads
25-08-2010, 12:37 PM | #33 | ||
a lot of people complain the rear doesnt go down low enough in the earlier e series too.
but when they fit the new lowered springs they forget to undo the control arm bolts and bounce the car to let it settle, the bushes in the control arms were originally tightened at standard height and with the lower springs in the bushes are actually holding the rear up a bit. the bushes can fail from being 'loaded' up like this. setting over a month is sometimes the rubber delaminating from the bush the control arm bolts can be tightened once the car is sitting with its full weight on the rear springs/wheels. best off done on ramps or a drive on hoist.
Money Talks, but all i ever hear is it saying Goodbye!! |
25-08-2010, 02:19 PM | #34 | ||
Critical Thinker
agree with Craig (my67xr) adjusting the rear control arm bolts to allow the diff to settle on the new springs is a must when changing the rear springs. I didn't fit my springs personally but I know mine were fit that way and the car settled almost immediately afterward. Then about a week later the car dropped in height another 5mm or so.
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
26-08-2010, 08:13 PM | #35 | ||
so i just get the car off the ground and loosen the lower control arm bolts, let the car down and bounce it a bit then tighten them up again? right?
26-08-2010, 09:33 PM | #36 | ||
im guessing no irs?
upper and lower arms need to be loosened, then bounce the body a few times, get in the boot and jump up and down the wheels need to be on the ground or on ramps or do it over a pit when u tighten the bolts up again
27-08-2010, 09:26 PM | #37 | ||
na i have irs im just gonna do the lower arms see if it makes a difference
