Old 04-08-2010, 12:01 PM   #1
amievil
Default How Often Do You Service Your Auto?
Hi
I have just recently purchased a AUII wagon.
As all of my previous cars have been manual, I have no idea on how
often I need to have the automatic transmission serviced.
I looked in the owners manual, but it doesn't help.
Can someone please help me with this?
I know if I just go to a mechanic, they'll probably tell me it needs to be
done on a yearly basis or something.
Thanks
Brad
amievil is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2010, 01:09 PM   #2
Stattic
Stattic's Avatar
If you drive hard, in the heat or you tow i'd get it done every year at the least, you can cook the fluid pretty easy without an external cooler
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2010, 01:15 PM   #3
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Helpful and detailed posts on car care.
I would say once a year for peace of mind, especially once your auto has done a few kms......wow you joined in September 2006 and this is your first post?!?! Welcome to AFF!!
No longer an 'active' detailer.
Dave_Obsession is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2010, 01:34 PM   #4
sleeper393
sleeper393's Avatar
THE AU's dont have a transmission dipstick , therefor you cant check fluid level , there a sealed unit so to speak , all that can be done by you is change the filter in the tranny pan attached to the valve body , other than that it has to go to a auto trans specialist, definetly fit a good quality external trans cooler after your service.[B]have a look below[/B]
http://www.fordforums.com.au/showthr...c+transmission
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak!
AU SERIES 3 LIQUID SILVER
BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS
123.4 GROUND TEARING RWKW'S , LOL
sleeper393 is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2010, 02:09 PM   #5
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Originally Posted by amievil
I know if I just go to a mechanic, they'll probably tell me it needs to be done on a yearly basis
That is because this is correct.
It would be very foolish to not do it yearly.
Old 04-08-2010, 04:40 PM   #6
redxm
64 Deluxe 4 door
redxm's Avatar
every 20 - 25k. cheap insurance (I tow a lot)
XM Deluxe
FG XR50
BA Pursuit Ute
redxm is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2010, 05:56 PM   #7
fatbats
I was told every 40k by my mechanic which is about what i do in a year.
fatbats is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2010, 06:06 PM   #8
The Monty
Just slidin'
The Monty's Avatar
20-30k for me. With a trans cooler. But then again, usually something breaks before that period is up and its in the shop being fixed anyway, lol.
MD Mondeo - For the family
NP Pajero - For the adventure
The Monty is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2010, 06:34 PM   #9
adrian k
adrian
adrian k's Avatar
Ford told me every 80kms.
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
adrian k is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2010, 08:43 PM   #10
The Monty
Just slidin'
The Monty's Avatar
Mines been running for 60 000k's and Ive had it in the shop 4 times, ahahaha.
Mind you, none of them were anyones fault but mine.
Service/flush/tans cooler/stall converter
Extension housing seal
Extension housing broke, Extension housing seal and bush/service/flush, output shaft and a tailshaft
Stall converter
Old 04-08-2010, 08:50 PM   #11
sneaky
sneaky's Avatar
i think my car went the first 170,000ks without changing the fluid
it was then changed by my mechanic, then 5000ks later it went to get a powerflush and service. i didn't notice any difference in the shifting.
it's been 12 months since it was changed, probably should think about it again
sneaky is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2010, 10:38 PM   #12
ronwest
All Bran = Regular Member
Good advice but you don't *have* to take it to a tranny specialist for a more extensive oil change:-
http://www.fordforums.com.au/showthread.php?t=11293691
ronwest is offline   Reply With Quote Multi-Quote with this Post
Old 04-08-2010, 11:59 PM   #13
JC
Miami Pilot
JC's Avatar
For non-extreme duty (ie around town) I'd say every 40000km (or once every 2 years is fine). If twoing heavy loads reguklarkly, yearly servicing with extend the life of the transmission. Also, keep in mind that even if serviced regularly, heat will kill a box quickly, so (if) as soon as it starts to slip or bang into gear, it's time to get to a transmission place - a few hundred $$$ upfront can save thousands if you leave it slipping or banging.
Ford Performance Club ACT
