03-08-2010, 07:28 PM | #1 | ||
Hardcore I6 Enthusiast
hey all, is someone able to show me a picture of what their rear suspension top mount looks like, i have a feeling the big washers and cap ontopt of the strut rubber were put on the wrong way round!
2002 AU XR6 VCT III 'ST' Liquid Silver Auto Full Momo and Leather Trim. Redback exhaust, high flow cat and Pacey Extractors. SELLING MY GENUINE 18" AZZUROS WITH TYRES. FRONT TYRES 95% REAR TYRES 50% |
03-08-2010, 08:08 PM | #2 | ||
Hope this helps
03-08-2010, 08:18 PM | #3 | ||
thanks heaps man but i cant really tell in the picture whic way around part number 9 is meant to sit, if i bolt it down with part 9 cupping towards the strut so it squashes the rubber, the noise is fixed, if i have it cupping towards the roof of the car theres play in the strut and it knocks
03-08-2010, 08:31 PM | #4 | ||
i just had a look at mine, they face upwards (bowl to the top).
03-08-2010, 08:47 PM | #5 | ||
by bowl to the top you mean it could be filled with water or the water will just run off it
03-08-2010, 11:16 PM | #6 | ||
yes filled with water like a dish
03-08-2010, 11:23 PM | #7 | |||
Falcon R.I.P. 1960 - 2016
Cheers |
04-08-2010, 01:10 AM | #8 | ||
exactly........
04-08-2010, 06:33 AM | #9 | ||
04-08-2010, 06:52 AM | #10 | ||
ignore that last post, compputers fault, damnit, iif i place it so it fills like a dish, the struts knock alot, i had the rubbers replaced a year ago....
04-08-2010, 09:08 AM | #11 | ||
You will need to fit a spacer washer between the mount (#10/11 above) and the "dish" washer (#9) - the stepped section of the strut is too long (or conversely, the mount inner sleeve is too short) so "dish" (#9) bottoms out on the shoulder before it clamps down on the sold centre sleeve of the mount (#10/11). Make sure the spacer washer will fit over the shoulder section but does not overhang the solid centre of the mount. If you turn the "dish" (#9)over all you are doing is locking up the upper mount.
Quick sketch to explain the above; Drawn from memory so may not be 100% correct in all detail, but near enough for you to get the idea. This was an issue from day one and is the most common reason the rear mounts fail - you would have most likely seen your old mounts had a oval centre hole rather than round when you replaced them.... When we had failures during warranty periods we did this as an 'in field' service modification when fitting the replacement mounts. Cheers James |
04-08-2010, 10:21 AM | #12 | ||
All Bran = Regular Member
Nice work.
Be right at home in the "Useful AU threads" sticky... |
04-08-2010, 10:22 AM | #13 | ||
XR6 4EVA i stumbled across this gem of a thread, i don`t know if you are having the same problem as in this thread ..... i know it has Koni`s but see what you think.
http://www.fordforums.com.au/showthread.php?t=11244643 |
04-08-2010, 12:22 PM | #14 | ||
perfect !! Thanks so much lads especially jimmy! Cheers for your quick responses!
04-08-2010, 06:40 PM | #15 | ||
adrian
Spacer is supposed to go under the top nut, ie ontop of the dished plate. Prob wont make too much difference though.
T3 TS50 #17 275kW AU3 XR8 SVP 220kW |
04-08-2010, 07:13 PM | #16 | |||
04-08-2010, 08:36 PM | #17 | |||
adrian
