13-09-2005, 06:01 PM | #1 | ||
FRIKA
I currently have condensation in my rear tail light. Anyone Know what the best thing to get rid of it is???? And dont say wipe it of with a cloth.
Are the tail lights eay to take off and put on????
New 2008 LV Focus XR5 in Performance Blue
13-09-2005, 06:12 PM | #2 | ||
Petro-sexual
Dunno about geting them off, never done it, but I wouldnt imagine it being hard.
Obviously its got a leak somewhere, and all you have to do is plug it up. I had water getting in my right rear indicator, all I did was glue up the leak and then drill a small hole at the bottom to let it drain off incase I didnt fix the leak properly. You should be able to find an inconspicuous (spelling?) spot to drill a hole if required. |
13-09-2005, 06:13 PM | #3 | ||
they call me Tibbo
they are easy to take off,, pop the boot, undo the 2 phillips head screws, then inside the boot, pull thrim trimaway to find a 10mm nut that holds the corner in, then twist the bulb holders out of the sockets.. BINGO..
Shove a rag over a screwdriver or a drift insert it where the bulbs go. Wipe the inside of the lense, or compressed air is better if you have access to that.. It is a good idea to drill a tiny drain hole on the inside corner of the lense to let the water run out.. I have seen them full of dirt, full of water like a fish tank and even full of mould :(
13-09-2005, 06:15 PM | #4 | ||
FRIKA
cheers for that ill see how i go.
13-09-2005, 07:24 PM | #5 | ||
mine do the same, they always dry by themselves if i park the cark in the sun
13-09-2005, 08:20 PM | #6 | ||
FRIKA
im just to padentic. Its obviously due to the weather. Im sure when it warms up it will go away.
