RBS
Old 24-04-2010, 06:13 PM   #1
leakey
leakey's Avatar
Default Removing Door panels 2008 FOCUS (lots a pics)
Hi All. I gave the guys in a recent 'speaker thread' the bum steer regarding how to remove door panels on a 2006 Focus. Well, mine's the update 2008 model, but this should be the same. So here is a HOW TO to make up for it.
This is quite comprehensive! Feel free to jump ahead.
Tools required -
Butter knife, set of TORX driver bits, small socket bits. (sorry dont know actual sizes) Small bit of stiff wire 200mm long. (I used the bit of flat wire you snap off a windscreen wiper blade) Flat blad screw driver.
1/. Pop out the blank panel/window switch in the door latch area. I used a butter knife. Set a side in a safe place.
2/. This allows you to grip the door latch cover. Pull it towards you. Pull the door latch towards you and then take off the cover. Set a side in a safe place.
3/. Pop off the door handle cover. I used a butter knife to start it. It is all clips. See how it looks when popped off. Set a side in a safe place.
4/. Unscrew the two small bolts. I used a small socket driver. Set a side in a safe place.
5/. FOR MANUAL WINDERS. Push the flat blade screw driver in between the window winder and the plastic washer behind it. Get bloody close to the door, and pull the window winder out towrds you so you can see behind it. You are looking for a silver grey clip. (see below) I made a small hook out of some flat metal. Push this behind the winder, and pull the clip towards you until it pops off. You can then remove the winder and the plastic washer assembly behind it. Set a side in a safe place.
6/. Starting at the door latch hole, gently pull the door cover towards you until it pops off. Continue doing this all the way around until its off. Done!
Notice how the speakers are rivetted in?!
I hope this helps a few of you out. If there are any major differences between fronts and rears, I'll do another HOW TO.
Cheers - Leakey
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR
leakey is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2010, 07:25 PM   #2
Velociraptor82
Eat my Brake Dust
Velociraptor82's Avatar
Fantastic work putting all that together Leakey.
Small Ford Sunday 2009 - Best Modified Car presented by the EuroFord Club
Small Ford Sunday 2009 - Best Focus (Non-XR5) presented by the RS Owners Club of Victoria
Sydney All Ford Day 2009 - Best in Club presented by The Combined Ford Clubs of NSW
Small Ford Sunday 2010 - Best Modified Car presented by the EuroFord Club
If I'm going to Hell, I'm going in a Ford
Velociraptor82 is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2010, 10:44 PM   #3
leakey
leakey's Avatar
My pleasure.
Old 24-04-2010, 10:52 PM   #4
leakey
leakey's Avatar
Just in case any of you are wondering, this is what the back of the door panel looks like -
Old 25-04-2010, 10:27 PM   #5
pcdougie
Da_Focus
Excellent work. Many thanks for this. I can't believe they used rivets!!
pcdougie is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2010, 05:45 PM   #6
DZFord
DZFord's Avatar
Thanks for the really comprehensive guides leakey, they may come in handy one day.
Old 28-04-2010, 10:20 PM   #7
20focus05
I wanna XR5
20focus05's Avatar
Top Stuff, good work
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
