12-03-2010, 07:47 AM | #1 | ||
Suspension Expert
G’day
Check out the WIN ONE OF 2 CARS! Or click on this link http://www.promoplace.com.au/V8super...onditions.aspx & register yourself down for the chance to win one of them not a bad prize to get considering the Suspension being Pedders Extreme XA Coil Over’s & DBA & Bendix equipped for brakes. So quite a few dollars worth of car to win. So good luck to those who register you just never know what may happen. :eclipsee_ :
Grant Phillips Franchise Owner 13 Phillips Drive, Kangaroo Flat, Bendigo, Victoria, Australia, 3555 Tel: +613 5447 0009 Fax: +613 5447 2229 Email: bendigo@pedders.com.au Multi Award Winning store Top Regional 03, 04, 06, 07.08,09,10 : Top Store 2005 & 2008 & 2010. |
12-03-2010, 08:45 AM | #2 | ||
Giddy up.
Thank's mate, youv'e got to be in it to win it.
12-03-2010, 12:48 PM | #3 | ||
5.8 litres of fun
sweet, thanks bungy
2003 RTV 2015 Ranger XLS mk2 |
12-03-2010, 12:55 PM | #4 | |||
Audi S3
12-03-2010, 01:31 PM | #6 | ||
Entered!!! New suspension in the Eskie would go very well! Although a whole new Ford XR6T would be nice
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery! Insta@mooneye_ghia White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly |
12-03-2010, 02:07 PM | #7 | ||
face: not open to nz peeps
12-03-2010, 02:19 PM | #8 | |||
Practicing - Sleeping with a guitar in your hand counts, as long as you don't drop it. Don't snap my undies. |
12-03-2010, 02:29 PM | #9 | |||
Broken eBay Starter Motor
Haha! My car had been partially Pedderised already, though the prize would still be an upgrade on what I have (red springs, struts, and bushes on a very low and nimble EF).
Unfortunately for me I can't enter, because the web page is giving me an error. :( Quote:
12-03-2010, 02:34 PM | #10 | ||
This is the error:
Server Error in '/V8Supercars' Application. -------------------------------------------------------------------------------- Timeout expired. The timeout period elapsed prior to obtaining a connection from the pool. This may have occurred because all pooled connections were in use and max pool size was reached. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.InvalidOperationException: Timeout expired. The timeout period elapsed prior to obtaining a connection from the pool. This may have occurred because all pooled connections were in use and max pool size was reached. Source Error: [code] Line 33: sqlParameters[0] = new SqlParameter("@templateID", ConfigurationManager.AppSettings["TEMPLATE_ID"]); Line 34: Line 35: SqlDataReader reader = SqlHelper.ExecuteReader(Constants.PROMOTIONS_CONNE CT_STRING, CommandType.StoredProcedure, Line 36: "praTblWebTemplateSel", sqlParameters); Line 37: [/code] Source File: d:\WebSites\Promoplace\V8Supercars\SidebySide.mast er.cs Line: 35 Stack Trace: [code] [InvalidOperationException: Timeout expired. The timeout period elapsed prior to obtaining a connection from the pool. This may have occurred because all pooled connections were in use and max pool size was reached.] System.Data.ProviderBase.DbConnectionFactory.GetCo nnection(DbConnection owningConnection) +1261381 System.Data.ProviderBase.DbConnectionClosed.OpenCo nnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) +105 System.Data.SqlClient.SqlConnection.Open() +111 Microsoft.ApplicationBlocks.Data.SqlHelper.Execute Reader(String connectionString, CommandType commandType, String commandText, SqlParameter[] commandParameters) in c:\documents and settings\simon\my documents\visual studio projects\microsoft data application block\sqlhelper.cs:881 MasterPage.getTitle() in d:\WebSites\Promoplace\V8Supercars\SidebySide.mast er.cs:35 MasterPage.Page_Load(Object sender, EventArgs e) in d:\WebSites\Promoplace\V8Supercars\SidebySide.mast er.cs:24 System.Web.Util.CalliHelper.EventArgFunctionCaller (IntPtr fp, Object o, Object t, EventArgs e) +15 System.Web.Util.CalliEventHandlerDelegateProxy.Cal lback(Object sender, EventArgs e) +33 System.Web.UI.Control.OnLoad(EventArgs e) +99 System.Web.UI.Control.LoadRecursive() +47 System.Web.UI.Control.LoadRecursive() +131 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1436 [/code] |
12-03-2010, 05:51 PM | #11 | ||
Thailand Specials
Sweet, I wouldn't mind me a free XR6T.
Thanks. |
12-03-2010, 08:02 PM | #12 | ||
Suspension Expert
Check Again guys it is a XR8 up for grabs!!! Yuo can also go to V8supercars.com.au & enter via their site also.
12-03-2010, 08:04 PM | #13 | ||
The first valid entry drawn in the Ford Prize Draw ("Ford Prize Draw") will win a 2010 Ford XR6 Sedan Turbo ("Ford") valued at up to $42,000 RRP (inc. GST).
The Ford is a 4.0 Litre Turbo Sedan with automatic transmission. Further details of the car are available at www.ford.com.au. The Ford is not a performance FPV Vehicle, The Ford is fitted with a Pedders Full Performance SportsRyder Kit including Pedders SportsRyder Suspension and DBA Brakes as fitted by Pedders valued at $6,000 RRP (inc. GST). The Ford comes in Silhouette colour only and the Holden in White, non-metallic only All Vehicle branding will be removed prior to the Major Prize Winners taking possession of the Vehicle. To the fullest extent permitted by law, the Promoter takes no responsibility for any mechanical, body or paint repairs from the date and time of collection of prize. So it's either a black XR6 Turbo or White SS, says the vehicles will be used from Sept '10 to Sydney 500, so it's not the current cars. |
12-03-2010, 09:08 PM | #14 | ||
BOSS 5.4L Enthusiast
Done and Done, FG XR6T would make a nice dailey.
13-03-2010, 02:13 AM | #15 | ||
Call me Spud
Done. I would love to win the XR6 Turbo seeing as I can't afford one. Now to sit and wait for december to come around lol.
13-03-2010, 06:31 AM | #16 | ||
Suspension Expert
Sorry guys My mistake as I had forgotten the cars get changed over mid season. My mistake on this one.
13-03-2010, 10:28 AM | #17 | |||
flickr |
