Old 17-02-2010, 01:06 PM   #1
munchkin323
AU XR6
munchkin323's Avatar
Default Brakes sticking? Wheel bearings?
Hey all,
Recently my 2000 AU1 xr6 has been having some dramas up the front of the car. At times when driving along the steering wheel will start to shudder heavily, when i pull over to check things the front arches smell like they do when under very heavy braking (burning smell).This is a tempromental problem and only occurs now and then. I jacked up my car the other night and the front wheels were very heavy to turn. There is still plenty of meat on the brake pads and under regular braking the steering wheel does not shudder. I do not hear any noises of interest when driving along so I am unsure whats going on?
I am thinking that this may be an issue with the brakes?
Anyone had this experience?
munchkin323 is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2010, 05:25 PM   #2
AU1monty
mine will shudder every once in a while and on occasions when stopping at traffic lights the steering wheel will pull to the left in the last 15 metres or so of stopping, smells like brakes aswell
AU1monty is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2010, 05:42 PM   #3
AMB
Technical Contributor: For members who share their technical expertise. - Issue reason: Always has a helpful answer in the technical sections, wether it's giving information on a simple diagnosis with a small issue, Helping someone fix their car if they are stuck on removing/installing something, or just need information on what works how.
Originally Posted by munchkin323
Hey all,
Do you mean that it starts to shudder and you get the burning brake smell, immediately after releasing the brake pedal, or a while after releasing the brake pedal ?
AMB is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2010, 06:30 PM   #4
svo supporter
Fixing Ford's **** ups
svo supporter's Avatar
It sounds like the caliper slides are starting to seize up. Pull them apart and grease them up. Should fix the problem
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises.
Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here
Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone
svo supporter is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2010, 06:55 PM   #5
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
As SVO said the caliper slides or the actual pistons will be sticking
With the car jacked up the wheels should spin freely by hand with a just slight rubbing noise, if you need 2 hands to turn them they are stuck on
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2010, 03:40 PM   #6
munchkin323
AU XR6
The shudder has been comming and going and has been happening while no braking is occuring. The problem got progressively worse the last day, i am pretty sure the front left caliper is stuck on. I have taken it the mechanic, so hopefully its not an expensive fix...
