Old 24-01-2010, 08:47 AM   #1
amiers
Default How long to warm up?
My Fairlane when warm would sit between the N and O. recently i put in a new radiator and it seems to take a long time to warm up. i can drive for at least 10 minutes before it gets to the N and it now rarely gets to the O, even on 30+ days.
so question is - how long should it take? and is a lower temp good or bad? i was told if its not running at the right temp the ECU will make it run rich
amiers is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2010, 11:44 AM   #2
mik
mik's Avatar
mine probably takes 10 minutes to warm up right through the metal, i`d have a guess though and say the thermostat opens up in probably half that time, so by 5 minutes it would be getting close to operating tempreture, i would`nt worry too much, it sounds pretty normal to me, unless it was staying substantially colder.
Old 24-01-2010, 02:31 PM   #3
JMO
JMO's Avatar
Might sound like an odd question but what would be bad about it being 'substantially colder' or taking longer than it should to warm up (e.g. thermostat stuck open)? What problems could/would it cause?
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2010, 03:28 PM   #4
Simsy
Simsy's Avatar
Sounds about right, my AU sits on the N on the temp.
Takes about the same time to get their.
Your old radiator wouldn't have been working as efficient as your new one and hence probaly making the temp to climb quicker (less warm up time).
Where did the temp sit before the new radiator went in?
Simsy is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2010, 06:53 PM   #5
cedric
if it is too hot ,it will run rich and take out timing. the boss motor tuners acctually use termastats that run a bit cooler to gain power from the factory computer leaning out and adding timing. so my guess is you will use less fuel
cedric is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2010, 07:00 PM   #6
lubby1
I always let it warm up for a few miniutes if possible and i try to keep the revs down untill it reaches normal operating temperature.
lubby1 is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2010, 09:59 PM   #7
mik
mik's Avatar
i`m not sure what tempreture the cold start cut off is, but if memory serves me correct there was a post about this sometime ago and 170 c was deemed safe, 160 was too cold but don`t hold my word to gospel, i run a 170 degree thermostat in mine it made very little difference , the fans cut in at factory preset :( probably 190 /195 i`m guessing, running in cold start mode runs richer(uses more fuel).
Old 24-01-2010, 10:08 PM   #8
blueoval
Critical Thinker
blueoval's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Well thought out and constructive posts.  A real credit to this forum.
I hear 82deg Celsius is the better thermostat to go for. Is this correct?
mik - from what your saying, the 170deg Fahrenheit/76deg Celsius is the lowest you advise before the cold start cutoff begins?
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2018 Hyundai Santa Fe Highlander
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 AU2 75th Anniversary Futura
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
blueoval is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2010, 08:59 PM   #9
Simsy
Simsy's Avatar
82 C/ 180 F is the temp BPT motorsport have for their thermostats.
Power Stat they call it.
Bought one but never fitted it.
They reckon you get an extra 3kw's out of it, but yeah.
Old 25-01-2010, 11:23 PM   #10
mik
mik's Avatar
if i remember the post correctly , it was 170 degrees minimum temp unless the parameters are changed with a flash tune, if it ran colder it would run in cold start mode .....fuel sucking rich, that was my understanding of it anyway, if i find the link for that thread i`ll put it up.
Old 27-01-2010, 10:52 AM   #11
blueoval
Critical Thinker
blueoval's Avatar
thanks mik. I might just get the 170deg F one. I think I have a stock one at the moment.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
