Old 15-01-2010, 07:24 PM   #1
troystanton78
IR84RD
Default major drama with auII 220 xr8
So, the other day (saturday before the monty cruise) was driving along minding my own business, took a right at an intersection, booted it, revved out first (its auto) backed off and she started making a horrible ticking noise, she's well under powered, won't idle, hard to start, but no smoke and when cruising at speed limit can't hear the noise only when accelerating although i'm sure its still there, any ideas on what it may be would be appreciated
cheers
Troy
ps its dual fuel
3rd generation Ford man
01 AUII XR8 220kw White
Last edited by troystanton78; 15-01-2010 at 07:26 PM. Reason: left out that its dual fuel
troystanton78 is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2010, 07:29 PM   #2
Windsor220
Now Fordless
Windsor220's Avatar
Sounds like you may have broke a valve spring.
Is the ticking coming from the engine itself?
Windsor220 is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2010, 07:36 PM   #3
cedric
YEP OTHERS HAVE HAD SIMILAR SYMTOMS WHEN THEIRS WENT oops
cedric is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2010, 07:38 PM   #4
troystanton78
IR84RD
yeah it is mate, i've wanted to start it up and have a closer listen, but have been to scared, the missus went away and took the laptop so no internet, just got back today, so i've thrown it out there for suggestions
Old 15-01-2010, 08:28 PM   #5
troystanton78
IR84RD
does anyone know if crow cams does a set foe the 220 engine, one other suggestion that i heard was a bent pushrod, is this possible
Old 15-01-2010, 11:11 PM   #6
Whoosha
AU DIE HARD
Whoosha's Avatar
More than likely just the spring , crow do do a replacement depending on the Ks on the motor you can just do the 1 or the lot , mine did 1 at 40000k just replaced the 1 and haven"t had a problem since and have done 100000k now
Originally Posted by Riksta
Old 16-01-2010, 07:53 AM   #7
DaveTE
Back in black
DaveTE's Avatar
Bottledup(Dave) can send you decent replacements from WA. On know the T-Series boys have used him for the same issues.
Black Mac TE50 S3 NO: 106
Little Mac AU S2 XR8
Bite the snake before it bites you!
______________
_.__ /________...\
_.._(___\\___//___)
.._..(O...\____/...O)
DaveTE is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2010, 05:04 PM   #8
troystanton78
IR84RD
thanks heaps for the help guys, appreciated
Old 16-01-2010, 05:14 PM   #9
b2tf
not here much anymore
b2tf's Avatar
Any good performance shop can get Crow gear (Autobarns can) and there is no need to wait for them to be sent from WA. Dave isnt @ A1 anymore either.
2024 F150 XLT
Old 16-01-2010, 05:20 PM   #10
CRAIGM01
was building the te,ts50 line in 2001 and 2002 and we were instaling to my knowledge yella terra rollers and rockers to the 220 engines and pretty sure ford had used springs from the same company. this info only helps if you want to run components that ford recomend.
CRAIGM01 is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2010, 05:26 PM   #11
troystanton78
IR84RD
thanks craig i'll check out there site
Old 17-01-2010, 07:00 PM   #12
RG
Back to Le Frenchy
RG's Avatar
Have a look and maybe get something other than crow.
I managed to break a crow spring and it took the valve with it so I'm a little wary now.
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
