Old 09-01-2010, 12:34 PM   #1
BongoKongo
BongoKongo's Avatar
Default Au Snuffs it in D & R
My car (99 AU) motor runs like a dream without a problem at any Rev range but when I put it into Drive or Reverse she instantly stalls.
I think it must be a seized Auto Transmission (probably a stuffed Torque Converter lock) or could it be something else?
Is it hard to replace the Auto on one of these beasts & will I need to buy a manual?
I was going to get used Auto Trans from a wrecker so how much should I pay for it? I go to UNI & don't have much money yet so I don't want to get ripped off by these Vultures.
BongoKongo is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2010, 12:45 PM   #2
frd906
Might not be a stuffed Tranny, can you drive it???
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2010, 12:49 PM   #3
BongoKongo
BongoKongo's Avatar
Nope, it instantly dies when I select any gear (except neutral of course) . Had to get it home on a truck.
Old 09-01-2010, 01:21 PM   #4
frd906
My bet would be to get it towed to a tranny place and get them to have a looksy at it,
cheers matt
Old 09-01-2010, 02:53 PM   #5
The Monty
Just slidin'
The Monty's Avatar
Go to a pick and pay wreckers, take take tools and a few hours and a friend, and learn how to take it out, and document it. Then pay the $150 for it, and take it home and repeat the process. Shouldnt be too hard and will take 246204
MD Mondeo - For the family
NP Pajero - For the adventure
The Monty is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2010, 03:36 PM   #6
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
do this for me: put your foot on the brake, dial up a few revs and pop her in drive. see if she stays afloat, if not, something srs is wrong. I wouldn't be changing my 'box on a whim.
Old 09-01-2010, 05:19 PM   #7
Beer Baron
I'm going to jump on Mr hardware's boat and agree to not change the box without enough cause. Also if its rolling at say 10kph in neutral and you drop it in drive does it still stall ?
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2010, 05:30 PM   #8
BongoKongo
BongoKongo's Avatar
OK I just did that, I brought the revs up fairly high & popped it into drive & Reverse and it just instantly dies (Motor just stalls).
The closest example I can give of what it is doing is that it feels like I'm popping the clutch in a manual with 5th gear selected to take off on a hill.
OK thanks The Monty but what does that mean?
Old 09-01-2010, 07:29 PM   #9
The Monty
Just slidin'
The Monty's Avatar
That means a customer came in when I was posting that, and I must have scanned part of a barcode, lol.
It was meant to say, should only take a day.
But yeah, Im with Mr Hardware, get it checked first IF its the gearbox, then go my route.
Old 09-01-2010, 08:02 PM   #10
JC
Miami Pilot
JC's Avatar
[QUOTE=BongoKongo]OK I just did that, I brought the revs up fairly high & popped it into drive & Reverse and it just instantly dies (Motor just stalls).
Does it do the same in 1, 2 or 3 as well? If so, could be torque converter, or transmission. Was the car drivable any time recently? If so, did it make any strange noises?
I'd be flatbedding it to the local trans place for a proper diagnosis, and once youknow what it is, you can weigh up your options. Bit hard to diagnose this sort of issue over the ethernet!
Ford Performance Club ACT
Old 09-01-2010, 08:46 PM   #11
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Helpful and detailed posts on car care.
Not to mention the INTERNET! :
No longer an 'active' detailer.
Dave_Obsession is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2010, 01:25 AM   #12
Stattic
Stattic's Avatar
should a stuffed transmission or converter be turning the car off? perhaps something is wrong with it electronically. id go to a good mechanic and get them to run a diagnostic.
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2010, 08:05 PM   #13
BongoKongo
BongoKongo's Avatar
No noise, No warning & it drove perfect. I just slowed down at a stop sign & it stalled and that is where it stayed until the RACQ trucked it home. He said that it was the Torque converter that had locked up.
The Transmission fluid pan was full of crud (bits of bands etc) so I pulled her out.
Went to the local wreckers & picked up a used one ( with torque converter because I think the old one may be rooted too - seized maybe).
Now comes the fun of lifting this bohemith & trying to bolt it back up to the engine block without doing myself an injury while still keeping both Nads intact.
Dam.. Those top 2 bolts are hard to get at & the starter motor bolts are a pain to get to as well.
Thanks for all your help guys, it is appreciated. :
Old 12-01-2010, 08:15 PM   #14
KR1STO
Just another mock-up..
KR1STO's Avatar
starter motors are the worst hey... that top bolt is a pain..
i've done quite a few auto's now.. in mine and mates cars.. they get heavier and heavier each time...haha
glad to hear you got it sorted..
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
