Old 10-10-2009, 02:35 PM   #1
frd906
Default Removal Of Glue On Rear Windscreen
ehy guy few months ago i decided to glue my roof liner back up to the car, now becuase it was summer it has melted all over my rear windscreen and is a paint to remove,
any recomendations on how to remove it off the glass
any products which work
cheers
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2009, 02:39 PM   #2
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Helpful and detailed posts on car care.
Get some Wax & Grease Remover.....or use some mineral Turps, or Prepsol.
And a paint scraper...
No longer an 'active' detailer.
Dave_Obsession is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2009, 02:49 PM   #3
frd906
oh really dont want to use a paint scraper as i dont want to scratch the window, but i will give the wax and grease remover a go, thanks
Old 11-10-2009, 08:11 AM   #4
Dave_Obsession
if it's a brand new scraper, you wont scratch the window.....I used one to remove all the leftover gunk on the rear windscreen after removing the factory phone kit.....came up beautifully, not a mark left!!
The trick is to go SLOWLY.......don't force / push too hard!!!
Old 11-10-2009, 08:49 AM   #5
frd906
thanks i wil go to day and get some wax and grease remover, i got half done other day, i used the thing they have at the servos to do clean your windscreen with, sprayed window cleaner on it, let is soak then i go in there and rubbed and rubbed managed to get 50 percent off, got bored after lollol
if i were to get the windows tinted, would they remove it for me
Old 11-10-2009, 12:03 PM   #6
Dave_Obsession
probably....ask them!!!
But not that hard to DIY. If window cleaner worked for you, then something like turps or even Methylated Spirits would definately work. Wax & Grease remover FTW though.
Old 11-10-2009, 12:47 PM   #7
gtxb67
moderator ford coupe club
gtxb67's Avatar
i am not sure what type of glue it is, but have you tried a hair dryer to heat it slightly and soften it
gtxb67 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2009, 03:48 PM   #8
frd906
yeh i will try some
Old 11-10-2009, 05:31 PM   #9
SLO AU XR8
Metho and a razorblade. Will get it off no drama's and not scratch.
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2009, 10:24 AM   #10
frd906
got thge glue off on the weekend used turps and a dish washing sponge and slowly rubbed it off, and got it all off cheers
