04-09-2009, 06:15 PM | #1 | ||
Hi guys i have picked up an AU XL ute 2002 and can't get it started. It is duel fuel 6cly. The radio is displaying "err" and i have the code but haven't been able to enter it becuase it won't let me.
All the electrics work fine as well Question is how can i get the radio back to the point i can enter the code and will this be what is stopping it start?? Thanks in advance, Rhys
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust. Wagon Build AU I Forte Sedan - No longer
Toy Car Build |
04-09-2009, 07:13 PM | #2 | ||
Worked out how to get the stereo code in by leaving the ignition on for 61 minutes and then it would let me put the code back in.
Same problem when going to start it though. Turn the ignition on to start the car and nothing happens at all except the fuel pump whirs for a second (this is normal as they all do it) but it should at least be trying to start.
Toy Car Build |
04-09-2009, 07:49 PM | #3 | ||
Flairs - Truckers Delight
try to jump it, see what happens
04-09-2009, 08:17 PM | #4 | |||
Thanks
Toy Car Build |
04-09-2009, 09:12 PM | #5 | ||
Maybe Smartlock?
04-09-2009, 09:14 PM | #6 | ||
If it's not even cranking over, is it in Park? Try putting it in Neutral and see if it starts (could be inhibitor switch).
04-09-2009, 09:16 PM | #7 | ||
or the ecu is playing up
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
04-09-2009, 09:20 PM | #8 | ||
i had the same issue with my car i put a smartshield computer out of a late model series 1 au into my smartlock lock earlier au,
and i have gone to start it and no crank at all, it would turn over but wouldnt start
04-09-2009, 09:26 PM | #9 | ||
2 4 turning 2 4 burning
it sound like the smartdhield is not linked to the ecu this will cause this problem from not starting. may need to tow the car to your ford dealer or a good auto elec so thay can be reprogramed.
05-09-2009, 12:28 AM | #10 | ||
Thanks for the replys guys,
I have tried starting it in park and neutral both without success. It will not even turn over. The car as far as i know has not had any ecu or other wiring changed at all and was only re regestered in june this year. So it is between june and now that it has been stopped at some stage and not been started again. 747JET i think you may be right in needing it all to be reprogrammed by ford but i was hoping to not have to do this as it isn't registered as it is on WOVR register. Thanks, Rhys.
Toy Car Build |
05-09-2009, 11:12 AM | #11 | ||
Feel the boost
might be silly but have u checked the very basics. such as the actual ignition wire still be on the starter motor. or if the vehicle had an alarm system tht was removed, could cause problems.
2005 BA Mk2 XR8 ...... Let the fun begin Drive carefully! Remember, it's not only a car that can be recalled by it's maker. |
12-09-2009, 05:45 PM | #12 | ||
2mny projects 2 lttl time
I had similar problem with my AU3 wagon.....
It was the BCM developed a fault Was looking at $130 for a s/h BCM from the wreckers, then fit it myself, $60 for a tow to Ford to get the BCM reprogrammed to suit my keys (another $120), so $310 all up......BUT........ 2 days ago bought a (matching) BCM, ECU, ignition and 2 keys on Ebay for $71 (thanks Wayne)......picked it up this morning, fitted it this afternoon, alls great........just came on here looking for the thread I started last month to report the conclusion and saw your thread Only thing is, the 3 items have to have come from the same car to avoid the cost /hassle of reprogramming Cheers Keith |
13-09-2009, 09:04 AM | #13 | |||
Walking with God
There are usually a set or two of these matching items on ebay. Worth looking out for. All the best with it. GK
13-09-2009, 04:17 PM | #14 | ||
just maybe look at the pink fuse in the engine bay and see if it has blown
