Old 06-09-2009, 10:12 PM   #1
sneaky
sneaky's Avatar
Default AU3 remote - lights are working, but nothing happens.
i tried to fix the spare au remote today as it wasn't working, no lights and no response.
when i cracked it open i noticed the little plastic platform thing the battery is in didn't sit into the circuit board like it should. so i put it back where it belongs and the lights worked.
now i have tried the remote and the light works on it but there is no response from the car, grr. no unluck/lock/boot release.
just wondering if anyone else has had this problem and how to fix it. i have already bought one replacement remote last year for the car, don't want to have to buy another... hmm, wondering if i could frankenstein one up out of the old dead one and this one..
cheers
-tim
sneaky is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2009, 10:24 PM   #2
SSD-85
Try reprogramming it, Put the car on i think acc or on position, and press the rear demister button 3 times within 5 seconds, the car should cycle its locks indicating its in learning mode, then press the lock button on your remote.
If that don't work, wreckers should have remotes on the cheap (er).
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2009, 11:29 PM   #3
UU TS50
T3 TS50 075
UU TS50's Avatar
mine is the same now so will try reprograming (spelling)
it and see how that goes
Cheers John
My car T3 TS50 #75 Blueprint manual 1/4 mile 13.38 @ 102.97 mph TS 50 = 237.1 rwkw
UU TS50 is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2009, 11:40 PM   #4
sneaky
sneaky's Avatar
cheers,
do i have to reprogram just the one that isn't working or both remotes?
Old 08-09-2009, 12:06 AM   #5
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Helpful and detailed posts on car care.
are you able to solder the battery holder back to the circuit board??
No longer an 'active' detailer.
Dave_Obsession is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2009, 09:20 AM   #6
Erich
you need to both remotes at the same time. Very easy (its in the manual even)
Erich is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2009, 10:35 AM   #7
BIGJB
BIGJB's Avatar
I had the same problem. Soldered back into place and lights up but no go.
So tried to reprogram the car but it won't work. Have done it before with this
car and many others so know what I am doing but for some reason it won't go into
(for lack of better wording) program function.
BIGJB is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2009, 11:20 AM   #8
TheSly1
Guys I had the same problems lights on the remote would work but it doesnt do anything this all of the sudden after i tinted my car on the weekend... ive checked all the fuses and all that.. but reprogramming it how Scotty85 (Thanks man) mentioned worked perfect..
car was on ACC and i just pressed the rear dimister button until the door locks cycled and pressed the lock button, now it all works again.. so thanks for that..
My remote insides have desoldered themselves.. must be a common fault
TheSly1 is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2009, 01:21 PM   #9
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Yes it is a common fault mate, i must have soldered up around 20 of the buggers by now...
Old 08-09-2009, 08:47 PM   #10
SSD-85
I'm more than happy to help. Honestly, I've only ever had this issue with E-series and AU1 remotes, the damn battery terminals get massively corroded from what looks to be moisture getting inside, lots of fun cleaning off
Old 09-09-2009, 02:36 AM   #11
sneaky
sneaky's Avatar
yes and no. i could, but the whole circuit board will probably get soldered together . i blame my tools
Old 13-09-2009, 01:40 PM   #12
kcej
2mny projects 2 lttl time
Funny thing.......I only just put a new battery in mine after a BCM meltdown
Didn't realise the battery holder is supposed to be soldered in tho ..... same thing, worked when battery first placed in, then wouldnt work at all ...... realised battery probably moving off contact, so I cut a small piece (6mm by 20mm) of some adhesive backed 4mm thick foam I bought once on a whim, stuck it to inside of back cover and WOO HOO ......works great
kcej is offline   Reply With Quote Multi-Quote with this Post
