Old 15-05-2009, 06:00 PM   #1
lofty
Rusticating
lofty's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent article on AU Power window installation.
Default Creaking brakes
When releasing the brakes on the ute, I get this loud creaking/groaning noise. Seems to me like it's the front brakes. It's annoying and a bit embarassing in car parks. A search brought up ball joints / tie-rod ends, but I'm not sure it's the same noise. This sounds like the staircase at the Munster's or something (showing my age). Could the pads be glazed? Thanks. PS: 126K on clock.
Territory SYII RWD, BFII RTV tray
lofty is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2009, 06:02 PM   #2
Nutcase
Mate I'm getting the exact same on mine. Still happening after new front discs and pads and ball joints. Might be rears though, hard to trace the sound when you are sitting inside.
Nutcase is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2009, 10:25 PM   #3
bodes-sh
usually rears, mine still do it a bit with new rear rotors, but no where near as much with the stock ones. it seems like the pads drag on the disc a bit, i guess you could pull them off and sand them back a bit to get rid of any glazing and see if that helps...
bodes-sh is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2009, 10:29 PM   #4
XR Lita
XR Lita's Avatar
It's not the handbrake band inside the rear rotors? I know mine squeaks from time to time when I take off from the traffic lights...
Stupid self adjusters....
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
XR Lita is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2009, 04:02 PM   #5
lofty
Rusticating
lofty's Avatar
Had another listen, and I think you're right, it's the rears. Which means it's probably the dreaded handbrake noise. Which means it's not really fixable from what I've been reading. Sorry to bring up an old subject; I thought it was the front.
Old 16-05-2009, 08:48 PM   #6
bodes-sh
handbrake is definitely fixable. basically what you need to do is, pull the discs off and file the leading and trailing edges of the shoes back, then check the adjustment. should be no more squeaks. i have done mine recently and it's perfect now. mind you it takes 6 or 7 clicks to hold, but no squeaking.
if it does the groaning as you slowly let off the brake pedal, it will probably be glazed rear rotors
Old 17-05-2009, 12:49 PM   #7
lofty
Rusticating
lofty's Avatar
That description sounds right. Just did a light deglaze on the RH rear rotor, but the noise is still there. Maybe I should just think of it as 'character'.
Old 17-05-2009, 01:42 PM   #8
bodes-sh
yeah, maybe, lol.
either that or a "standard feature"
as i said, after replacing the rear rotors with slotted rda's it doesn't do it anymore, so i'm not sure... good luck fixing the problem...
Old 18-05-2009, 07:38 AM   #9
lofty
Rusticating
lofty's Avatar
Anyone tried Reliance rotors?
http://cgi.ebay.com.au/ws/eBayISAPI....m=140321294163
http://www.bpa.com.au/autoprodrotors.html
Old 20-05-2009, 11:09 PM   #10
Stattic
Stattic's Avatar
au brakes hate reversing
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2009, 04:46 PM   #11
AUbigfoot
Ford beginner
AUbigfoot's Avatar
Unfortunately it sounds like it's the common handbrake issue. That squeal noise is something a lot of us AU owners are getting used to :(
2002 Series 3 AU Fairmont
aufalcon.com/bigfoot
Build thread:here
AUbigfoot is offline   Reply With Quote Multi-Quote with this Post
