Old 16-05-2009, 05:28 PM   #1
needaXYGT
AU II XR8
needaXYGT's Avatar
Default Au Xr8 II-III
Hi, iv been looking at buying an AU XR8 for some time now and have found an AU XR8 REBAL with 65,000ks on the clock, now just playing the waiting game, cause the dealers are trying to rip me off!
Just wondering if you guys can give me some ideas of what to look for when going over the car, example, any common engine problems the windsor might have.
thanks.
AU XR8 II ute
XD FAIRMONT GHIA 302
XA FAIRMONT 302 TOPLOADER
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2009, 05:57 PM   #2
dreadly
rebels are sweet! They kinda have a 2 tone kit. 220kw handbuit engine, special mags, leather, etc. Best bet when buying a car get a nrma check about $150 save ya heaps in the long run, or even your usual mechanic. But at 65k it's barely broken in ;).
If not start with service books, should have had a recall for the steering colum- wasnt anything major. Look for leaks at the engine, gearbox, and diff etc. Take it for a spin see that it steers all straight, do some u turns etc listen and feel for wheel bearings, control arm sounds squeeks rattles etc, take it out on some 100km roads and listen for diff whines. Depends if it's auto or manual, auto feel for nice shifts- no lag or waiting for it to change gear etc. Manual you want nice smooth shifts that arnt to clunky but au xr8 manuals kinda do anyways lol, Go around and push down on each corner of the vehicle and you want them just to bounce back and stop. not alot of bounce back. The windsor engine is pretty good a little asthmatic lol but some on here have done 300k+ and still going strong.Rebels have the 1.72 YT's and 70mm T/B and svo alloy heads, so there a good starting ground for mods,Also regular maintance and tlc will see yrs out of it ;) Other than that? sounds good got any pics? and ask em if there gonna chuck in a ps2+ grand tourismo
dreadly is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2009, 06:03 PM   #3
needaXYGT
AU II XR8
needaXYGT's Avatar
Do you remember the problem with the steering colum?
AU XR8 II ute
Old 16-05-2009, 06:12 PM   #4
dreadly
Umm ring ford with the vin and they'll tell you if it needed doing or has been done. Cant remember i had to get mine done or i think we didnt bother and just had it listed as done? lol it'll come up on the screen when you get a service at ford.
Wasnt anything major hey think they add a bolt or something? should be sweet as.
How much are they asking?
Old 16-05-2009, 06:21 PM   #5
b2tf
not here much anymore
b2tf's Avatar
It wasnt the column it was actually the steering rack and from memory it was only 6 cyl models that were affected. my old AU3 never had any recalls done and never needed any.
2024 F150 XLT
Old 16-05-2009, 06:33 PM   #6
dreadly
Was all au 2 models. No mention of series 3.
Old 16-05-2009, 06:38 PM   #7
needaXYGT
AU II XR8
needaXYGT's Avatar
Thanks for the info so far. The asking price is 20k, but iv managed to get it down to 16k, still not low enough for my liking though. Last time they had an Au XR8, they did the exact same thing, price was to high, so it sat there for 3 years and rotted away with only 46k on the clock, but they reakon they can get more for it. If they can, then good luck to them, ill just have to find another one.
AU XR8 II ute
Old 16-05-2009, 06:45 PM   #8
dreadly
$16k is good Turn up with $15K it's an awesome buy hey ;) considering 65k ago it would have been $45k+ you saved $30k off purchase price and it's had 3 services : I say without seeing it go for it!
Old 16-05-2009, 08:48 PM   #9
needaXYGT
AU II XR8
needaXYGT's Avatar
Is this the engine they were fitted with?
Windsor 5-litre V8, OHV, electronic multi-point fuel injection, 9.0:1 compression, SVO Y303 alloy heads with larger valves and ports, roller rockers, 70mm throttle body, EEC V engine management system, special cam shaft, electronic ignition, extractors, 220kw @ 5250rpm, 435Nm @ 4000rpm
AU XR8 II ute
Old 16-05-2009, 08:53 PM   #10
cedric
no. alloy heads were only on te 50 series one.exactly same car as series 3 xr8
cedric is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2009, 08:56 PM   #11
Andrew92
i believe that is correct
Andrew92 is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2009, 10:00 PM   #12
dreadly
Yep thats right, cedrics wrong
Old 16-05-2009, 10:54 PM   #13
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
Doesn't matter much,,there's an obvious weight saving with the alloys but at the end of the day, alloy or iron its still 220 killer wasps.
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2009, 12:40 AM   #14
5 FTR 5
Made the 300 :0)
5 FTR 5's Avatar
NO they had cast heads from what i can find ,Also 9:4:1 Also a cam from Crow Part No 621338 which was mild because the heads flowed good with the valve size and alittle porting by yella terra.
New Owner of a fiesta ST
5 FTR 5 is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2009, 12:44 AM   #15
FTe_XR8
formerly "3x-puursui7"
im led to believe some were lucky enough to get alloy heads as they were left over from the t-series or i might be thinking of something else?
all hail the mighty V8's
http://www.aufalcon.com.au/3x-puursui7
FTe_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-05-2009, 11:19 AM   #16
galaxy xr8
Giddy up.
galaxy xr8's Avatar
They did NOT have alloy head's, period.
They were a stand alone XR8 series III special , the same engine as every other series III XR8 220.
Old 17-05-2009, 11:48 AM   #17
Peuty
Afterburner + skids =
Peuty's Avatar
Not to nit pick, Rebels were a series 2.
No alloy heads, they had cast GT40P's.
Oo\===/oO
Old 17-05-2009, 01:00 PM   #18
dreadly
Guess i was wrong then sorry about that. Or could it be a case of the au xr8 ute some got 1.72's some got 1.6 RR's. Maybe someone out there has one with alloys?
But still they only made 250 of em, There a nice car and 65k for $15-16K is a good buy
Stick some pics up or a link to it?
Old 17-05-2009, 01:06 PM   #19
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Yeah my bad,
I meant they were the same engine as the series III 220kw.
Old 17-05-2009, 06:08 PM   #20
needaXYGT
AU II XR8
needaXYGT's Avatar
ok thanks guys. the car isnt adverstised online and i dont have any pictures of it. I beleive there was only 125 of them made as well?
AU XR8 II ute
Old 17-05-2009, 06:14 PM   #21
dreadly
Well if thats true..... go get it lol ;)
Old 17-05-2009, 06:50 PM   #22
GK
Walking with God
GK's Avatar
I agree, go and get it. Walk in with 14K cash and drive it home. If they say no, do what you had planned to, and play the game by walking away.
They got it for much less than 14K so I reckon they just might take it.
All the very best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 17-05-2009, 09:30 PM   #23
b2tf
b2tf's Avatar
No factory alloy headed XR8's exist as far as I know, if they do exist it's more than likely something the previous owner did.
The Rebels are a good bit of kit but a Series III with just as many options ticked is pretty much the same vehicle so don't be conned into paying extra coin just because it is a Rebel - unless you get the playstation that went with the car when they were sold new.
2024 F150 XLT
Old 18-05-2009, 04:46 PM   #24
redauxr8
LOL
redauxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2009, 05:59 PM   #25
dreadly
Hey new guy... Get &^*ed! :the_finge
Have a look at every post you've done..... bahaha dont smart being cheeky after 2mths!
Old 19-05-2009, 06:25 PM   #26
redauxr8
LOL Settle down, i just thought it was funny.... Damn man chill....
Old 19-05-2009, 06:31 PM   #27
dreadly
So's pretty much everyone of your posts.....38 in -8weeks lol :
Thats enough outta me lol im sick of getting banned py:
Old 19-05-2009, 06:43 PM   #28
Peuty
Peuty's Avatar
Oo\===/oO
Old 20-05-2009, 01:00 AM   #29
dreadly
Hahahahah Thats awesome peuty! Indeed lol
