Old 04-04-2009, 05:35 PM   #1
The Monty
Just slidin'
The Monty's Avatar
Default Part enquiries for higher HP.
Im after opinions as to what parts to use though in the next step of the build in my blue car.
Basically, when it was getting tuned on Wednesday we found a few issues.
One was that the intake is too restrictive.
The other was that they started running out of fuel around 4900rpm.
This means, with 152kw atw, they still have another 1300rpm to tune before its done.
I need advice on :
Fuel pump
Plug leads
Tyres (slicks)
and intake.
I also have to change injectors, to XR6t injectors, and am changing the cat to a 3 inch ballistic racing cat.
For an intake, my only idea is to go straight through the bonnet, I have no issues with this, but Im keen to hear peoples ideas, no matter how radical they are.
Personally, I want a 14 in round air cleaner with chrome top straight through the bonnet, but am unsure on legalities.
After all that, it will need a bit more play on the tuning side of things.
I will need slicks too, as now, with only 22psi, I cant get traction at the strip, I can only stall to 2300RPM, and the cam doesnt come on till 3000rpm on.
My 1/4 times in shocking weather was a 15.02 @ 93 mph, with 2.2 60's because I cant get traction. :
So post away, let me know some ideas on the items I need, and part numbers and suppliers if you have them.
Thanks,
Josh.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 04-04-2009, 10:36 PM   #2
Cam
Stroking it...
Cam's Avatar
Well some of this we have discussed previously, but I will give my opinions anyway...
Fuel Pump - From what i can remember the pump in your car should hold up a bit longer, otherwise I'd be going for a bosch 040 intank pump. But with new injectors you should be right..
As for leads? There is a dude on here I think in brissy who makes his own, have heard very good results from them. I am sure blackers can provide more info.
And slicks, It'd depend whether you want to be able to drive to the track with them, or not?
Intake? If the pod is exposed, its illegal, its like flashing your c*ck in public, its not allowed.. And with it running through the bonnet rain is an issue. I'd be more likely suggest to run a pod behing your front bar before hacking your bonnet.. Otherwise look at one of the group buy CAI's and some decent intake piping and keep it legal..
Had: 347ci AU
Then: Stock AU fairmont wagon...'05 AWD Terri GHIA on Gas.. and a caravan..
Currently traveling OZ Travels over, follow me at http://Facebook.com/gonecaravaning
Now: Busted assed EB Wagon - 5sp and Dual Fuel.
Cam is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2009, 01:20 AM   #3
SLO AU XR8
Buy OED666's 3" Mandrell bent intake piping, Get decent tyres, you shouldn't be turning them with a 3000rpm stall but only leaving at 2300rpm.
What are the plans for the car? Boost? if so, mod the fuel pump cradle for an 044, otherwise, the stock pump should be fine for 185rwkw
GT 335
11.3@124.1mph
383rwkw/513rwhp
Forced Performance Tuned
SLO AU XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2009, 01:38 AM   #4
Stattic
Stattic's Avatar
152rwkw and the injectors arent coping???
let mw know how you go, i might need to change my injectors when i get my cam and springs etc done
also very keen to see the results with a better intake, i was going to buy a big mouth and some piping the other day but i reckon big mouths still might not give me that much of an increase in flow simply because where theyre positioned
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2009, 01:41 AM   #5
EvilChief
Boost Addict
adjustable FPR
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2009, 06:34 AM   #6
The Monty
Just slidin'
The Monty's Avatar
Okie dokie.
I know a shaker is legal, maybe just a shaker hat, moulded into the bonnet, with the pod into it.
I didnt break tracction leaving the line at 2300, 2300 is as high as I could stall without breaking traction, I have a 3000rpm stall converter, and i cant even use it properly as it just goes sideways.
152kw on one dyno might be 170 on another, and 130 on another, my tuneis at 152kw on this dyno, and this is where I am running out of fuel. If I remeber correctly, Stav was running out of fuel at 166kw on the dyno he was using.
Down the track Im not sure whats in store for it, maybe S/C and NOS just for fun at the track, deregister it and just use it as a drag car.
As for OED's intak, whats he changing to if he's selling his intake? He'd have something up his sleeve, and I want in, lol.
When I was launching with the other tune the other week, I was running 235/45 17's, at 30psi, and even with so little power down low, it would still chirp off the line at 2500rpm.
Evilcheif, whats an adjustable FPR?
One other thing I would like to know, I cant even get the stall to stall up to max stall speed, one due to wheelspin, but if I use the handbrake and foot brake, it gets to 2600 and just starts creeping forward, I cant get the car to stay still. Would a transbrake fix this? If so, what would I be looking for in the way of one, and how exactly do they work.
Old 05-04-2009, 07:28 AM   #7
Cookie-XR8
SKID IT
Cookie-XR8's Avatar
for the intake, just get 3inch piping down into the front bar somewhere where it can suck cold air,
what power are you looking for?
Style, Create Your Own
BF XR6T Ute - 422rwhp tuned by FPT Toowoomba
Where the boost junkies hang out -Forced Ford Forums
Cookie-XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2009, 07:36 AM   #8
The Monty
Just slidin'
The Monty's Avatar
Who knows, whatever its got. The restriction on the intake wasnt the way the pod was setup or anything, that was fine, it is that Im using a three inch pipe to the slinky elbow, and standard intake from slinky on. I used to have a 3 inch s/s mandrel bent one, but it didnt sit flush with the throttle body, and was always rubbing on the bonnet, and it was driving me insane, so I hacked it up, lol.
I want to go through the bonnet, Im not in this for looks, I have a bonnet waiting for hacking, so why not? Others have done it beofre me, and by reducing intake by two corners, and nearly a Meter of piping, I cant see how thats going to hurt at all?
Old 05-04-2009, 07:40 AM   #9
Cookie-XR8
SKID IT
Cookie-XR8's Avatar
do it, just straight off the throttle body about a 70 deg bend then pod filter, might not be center though
Old 05-04-2009, 08:11 AM   #10
The Monty
Just slidin'
The Monty's Avatar
Centre Schmenter. Ill do that and a shaker top or something, maybe a hilux scoop, lol.
Mods can you please delete this thread?
I basically couldnt be bothered asking for advice anymore.
Old 05-04-2009, 08:36 AM   #11
Cookie-XR8
SKID IT
Cookie-XR8's Avatar
sorry
Old 05-04-2009, 08:40 AM   #12
The Monty
Just slidin'
The Monty's Avatar
No, not you, lol. Your help was GOOD help. most of this thread has been good help, its just other things, lol.
Are you on MSN? If so, PM me your email, and Ill add you.
Old 05-04-2009, 08:44 AM   #13
Cookie-XR8
SKID IT
Cookie-XR8's Avatar
im at work, lol
cant do anything on the work pc :
there is few websites that are allowed now too
Old 05-04-2009, 09:49 AM   #14
StealthAu
Get the shaker, no issues in qld when I looked into it. Leads, get onto qld ignition, as far as the fuel pump goes, factory will hold up fine beyond what you'll be putting out.
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2009, 10:20 AM   #15
AU1XLS
AU1XLS's Avatar
FPR = Fuel Pressure Regulator
AU1XLS is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2009, 11:25 AM   #16
SLO AU XR8
The Monty, OED has some DOHC Turbo goodness coming....
GT 335
11.3@124.1mph
383rwkw/513rwhp
Old 05-04-2009, 12:56 PM   #17
The Monty
Just slidin'
The Monty's Avatar
Ohhh, I see, lol.
As for fuel pump, it probably wont stay NA forever, soI might as well upgrade before a tune, get it all sorted out. At the moment, I cant even try and push it around a corner, it just starts to die.
Old 05-04-2009, 02:03 PM   #18
StealthAu
Originally Posted by The Monty
Ohhh, I see, lol.
Yeah sounds like you need a new pump then, the stock ones are good for at least 200rwkws, I know this much. If you do plan on going beyond this, I'd still keep the stock pump, add a surge tank and inline pump that can cope with what you want/have planned.
