Old 26-12-2008, 10:01 PM   #1
namecrap
Default BEM upgrade
am wanting to fit a high series BEM to AU xl ute...
im guessing its not a plug and play exercise...
are the plugs and pin assignments much different?
namecrap is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2008, 08:27 AM   #2
Mechan1k
Mechan1k's Avatar
I have a pink high series BEM sitting around at home ... but AFAIK it's a Series 2/3 BEM.
I may not work if you have a Series 1 with Smartlock.
Old 27-12-2008, 10:41 AM   #3
namecrap
would anyone have a BEM (low and high series) wiring diagram for S1 AU...
ive got one for S2 but it will be different to S1
Old 27-12-2008, 11:39 AM   #4
russellw
russellw's Avatar
You will find the BEM schematics HERE
Russ
Old 27-12-2008, 11:43 AM   #5
namecrap
Russ
that would be nice but I keep getting a screen that says this :
"You do not have permission to view the images in this category."
no idea why
Old 27-12-2008, 11:45 AM   #6
namecrap
ok prob solved.....i had my browser set to not remember passwords (because im paranoid!! haha)
cool its working now yay
cheers
Old 27-12-2008, 08:20 PM   #7
namecrap
any ideas what would happen if you swapped a high series bem into where a low has been? could bad things happen..ie frying something
Old 28-12-2008, 12:01 AM   #8
Papa Smurf
Papa Smurf's Avatar
As far as I know, NO namecrap. I have an AU XR6 series 1 which I am putting a High series BEM into and there is no probs doing so.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2008, 09:38 AM   #9
Mechan1k
Mechan1k's Avatar
The only thing that needs to be done afterwards is get your keys retrained from memory ... and that would need to be done through the WDS system at Ford.
Old 28-12-2008, 11:22 AM   #10
namecrap
any idea what that would cost?
Old 29-12-2008, 05:53 PM   #11
namecrap
just tryed putting a high series bem and ecu from vct motor (smartlock) into au ute (smartshield)...wired up a smartlock barrel and it all works fine...well at least it runs (havent checked everything yet tho)...
now to find a vct head...anyone?
