Old 06-11-2008, 12:53 PM   #1
james22
With da Warlords
james22's Avatar
Default Uh oh... Strange Noise
Hey all.
I think I've damaged the engine in my XR again. : There is a strange beeping sort of noise, that appears to be coming from the rocker area of the engine bay.
Tried the screwdriver stethoscope trick, and I've narrowed it down to the Cylinder 5 area.
Weird noise, just sort of goes Beep, beep, beep beep beep, beep.
I'm suspecting another valve spring, (well I hope thats all it is)
Whats your opinion?
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2008, 01:18 PM   #2
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
Whatever it is... GET IT FIXED BY NEXT WEEKEND! :P
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2008, 01:28 PM   #3
james22
With da Warlords
james22's Avatar
Yeah bro, I'm gonna try. I can't believe how this stuff happens just before trips like this.
Its very strange, generally from what i've heard. If a spring breaks, the car starts missing through the rev range, and in some cases drops the valve which of course is a bad thing.
Problem is that the car is not missing at all. Its a bit rough at idle, but it always has been. I can't notice a change in how its running, except for this strange sort of beeping noise.
Windsor Warlords
AU III XR-8220
Old 06-11-2008, 02:06 PM   #4
james22
With da Warlords
james22's Avatar
Does anyone think this is a valvespring? Doesn't seem right to me.
I'll pull the rocker cover off and have a look, take a few pics.
Windsor Warlords
AU III XR-8220
Old 06-11-2008, 02:56 PM   #5
b2tf
not here much anymore
b2tf's Avatar
It doesnt sound like one mate but its very hard to diagnose without hearing them. Dont you have Crow springs in there anyway?
Could it be a noisy lifter? When was your last oil change?
2024 F150 XLT
Old 06-11-2008, 03:00 PM   #6
james22
With da Warlords
james22's Avatar
Oil changed yesterday, I thought that may have been a problem, but its probably worse after I changed it.
Crow springs, Yes in one cylinder lol. When it broke the spring in the smash repairers I only had the single one replaced.
Lifter noise? I have no idea what it sounds like...
Windsor Warlords
AU III XR-8220
Old 06-11-2008, 03:03 PM   #7
b2tf
b2tf's Avatar
You only did ONE spring?! Ya bloody loon! : :
Even if it isnt the spring spend the $100, get 7738 Springs from Crow and put em in!
2024 F150 XLT
Old 06-11-2008, 04:45 PM   #8
james22
With da Warlords
james22's Avatar
^^^ Lol, yeah didn't have funds at the time
Well I pulled the rocker covers off. Found no problems under there.
All springs appeared to look ok, bit hard to tell.
All rockers moved up and down in sync when I turned the engine over.
All the pushrods are centred.
Springs appear to be seated ok.
I'm putting it back together right now and I'll see if I can pinpoint the noise again.
Windsor Warlords
AU III XR-8220
Old 07-11-2008, 07:30 AM   #9
james22
With da Warlords
james22's Avatar
Well next time, I'll spend a little more time diagnosing the location of the sound lol.
After pulling the top half off and inspecting everything, I found that it's all in tip top shape.
So I re-assembled the car, started it and tried pinpointing the noise again.
I could still hear the noise through cylinder 5, but whats underneith that on a V angle....
The bloody waterpump. Thats all it is, had me shittin bricks lol
Windsor Warlords
AU III XR-8220
Old 07-11-2008, 08:26 AM   #10
RG
Back to Le Frenchy
RG's Avatar
That's IT, I will be relieving you of your XR in Albury. It needs a better home :
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2008, 08:43 AM   #11
InfernoSR
InfernoSR's Avatar
Oh... thats harsh! :P
Old 07-11-2008, 09:00 AM   #12
james22
With da Warlords
james22's Avatar
Na uh, You want my XR you gotta get through Adam first . Besides I don't think he wants to walk home, (not that it'd do any harm lol) : j/k mate
On a more serious note though. After this scare with me thinking I'd rooted a valve spring, I think I'll take Austins and undoubtedly your advice russell, to change all the springs over to new ones. Its not worth the risk over a $100 saved.
On a side note, does anyone know how to remove the pulley on the water pump?
Windsor Warlords
AU III XR-8220
Old 07-11-2008, 09:10 AM   #13
james22
With da Warlords
james22's Avatar
P.S ADAM - Clear your PM's mate, you message hoarder lol. Can't send you anything
Windsor Warlords
AU III XR-8220
Old 07-11-2008, 09:13 AM   #14
InfernoSR
InfernoSR's Avatar
There you go whinger! :P
Old 07-11-2008, 09:15 AM   #15
Mont5.0
Mont5.0's Avatar
Not sure if they come off? when i replaced my pump, already had new pulley on it.
FGII XR6 IN LIGHTNING STRIKE
R52 SIII IN GUN METALLIC
Mont5.0 is offline   Reply With Quote Multi-Quote with this Post
Old 07-11-2008, 10:02 AM   #16
b2tf
b2tf's Avatar
Mate I think I have some 7738 springs unused from when I did the heads. I'll check and get back to you.
2024 F150 XLT
Old 07-11-2008, 10:06 AM   #17
james22
With da Warlords
james22's Avatar
Ripper Appreciate that.
Why didn't you use them though? Edelbrock heads had better springs did they?
Windsor Warlords
AU III XR-8220
Old 10-11-2008, 09:35 AM   #18
InfernoSR
InfernoSR's Avatar
Any luck over the weekend?
Old 10-11-2008, 09:57 AM   #19
blackers10
blackers10's Avatar
there is a pulley removal and refit tool you can get from auto shops james22
its like a castle shape
On The Street Feature Winner Performance Ford Mag
See my car at:-www.aufalcon.com/blackers10
blackers10 is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2008, 11:06 AM   #20
james22
With da Warlords
james22's Avatar
Not yet. I don't think I'm going to albury.
Can't afford the pump and the petrol and associated costs together.
If I replace the pump I'm out
If I don;t replace the pump I could come, but 1200km on a rooted pump is asking for trouble. The last thing I want to do is cook my engine.
So I'm preety ****ed off right now :
Windsor Warlords
AU III XR-8220
Old 10-11-2008, 11:09 AM   #21
RG
Back to Le Frenchy
RG's Avatar
Are you sure that there is a problem with the pump and it isn't just a squeaky pulley?
Old 10-11-2008, 11:17 AM   #22
james22
With da Warlords
james22's Avatar
Yeah nearly positive. I can hear the beeping sort of noise inside the car with the music on.
Used a long screwriver and sat it ontop of the waterpump housing, and you can clearly hear the evil sort of noise in there.
P.S - I might try pulling the belt off, and turning it over by hand. It should spin preety freely right? If I can feel resistance when turning it that would nearly have to assure that its buggered right?
Windsor Warlords
AU III XR-8220
Old 10-11-2008, 11:30 AM   #23
RG
Back to Le Frenchy
RG's Avatar
Do that, I have a bit of a squeaky pulley on mine but it's not as loud as yours.
Old 10-11-2008, 11:35 AM   #24
InfernoSR
InfernoSR's Avatar
If its still in the car, then there will be resistance from the water... unless you drain it... if pulled out of the car, then it should spin freely.
Old 10-11-2008, 11:56 AM   #25
james22
With da Warlords
james22's Avatar
Any other ways of testing if its buggered?
Windsor Warlords
AU III XR-8220
Old 10-11-2008, 12:38 PM   #26
InfernoSR
InfernoSR's Avatar
Well by the sounds of it... its not the impellor blades... otherwise your car would be cooked by now... sounds like it could be the bearings... but if you are lucky... it might just be some loose crap floating around too...
Old 10-11-2008, 01:09 PM   #27
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
Well if you turn it on the car and it was bugger'd i'd assume you would feel some inconsitantcy too it and that it would probably have a tighter spot in it, as for if squeaky pully, spray some crc down onto pulley and see if squeak goes away, just be careful though, although it shouldn't come off, i have seen the belt come off from people spraying crc on with engine running.
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2008, 01:14 PM   #28
RG
Back to Le Frenchy
RG's Avatar
I'd go Silicone Spray to lubricate it as opposed to CRC/Penetrene/WD40/think of all the other names for it.
Although a spray of CRC may just dislodge some gunk build up behind there.
