07-11-2008, 11:01 AM | #1 | ||
Critical Thinker
Some of you already know I have new RDA rotors and pads from a group buy about a month ago.
I havent fitted them yet as I have been slack as well as busy. :P I have a few questions before I fit them so Im 100% confident in doing the job right. 1. Do I need to buy new bearings prior to fitting the new rotors or can I clean & regrease the existing ones sufficiently? 2. Is it recommended that I do a complete brake flush while in the process of fitting the new brakes? 3. How difficult is it to fit the rear rotors and do I need a special tool to assist me? 4. What other issues do I need to be aware of when in the process of this change?
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
07-11-2008, 11:26 AM | #2 | ||
With da Warlords
1. No, but if you think they are wearing out, you could save some time and effort now.
2. Depends on how long since its been done. Personally for me "Yes" 3. Not that hard to change. Special tools hmmm "Rubber mallet comes in handy, they can be reasonably hard to get off (rusted) 4. Remember to use loctite on the thread and torque wrench to get everything pinched up nice. Can't think of much else right now Goodluck :-)
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 300+ rwhp of Manual fun XR50T Ute - 300rwkw (give or take depending on the day)
07-11-2008, 11:29 AM | #3 | ||
Critical Thinker
thanks James.
Things to add to my shopping list: * Loctite * 1tr bottle Dot 4 brake fluid * mallett
07-11-2008, 12:13 PM | #4 | ||
Critical Thinker
Im thinking I might get new bearings to be safe. Afterall, these current bearings have been in the car since factory and they have done 130,000km.
Any idea what the front bearings will cost new?
07-11-2008, 12:18 PM | #5 | |||
Back to Le Frenchy
Front is a sealed unit so you replace the entire hub assembly.
07-11-2008, 12:23 PM | #6 | |||
Critical Thinker
07-11-2008, 12:27 PM | #7 | ||||
Back to Le Frenchy
07-11-2008, 12:40 PM | #8 | ||
Critical Thinker
Aaaah thanks for the heads up Russ. I never new that. Im guessing a sealed unit isn't cheap to just by from motor traders, repco etc.
They bearings within the sealed unit arent making any noise at all. Would I need to regrease the unit prior to refitment or is there no need to do that?
07-11-2008, 01:09 PM | #9 | ||
With da Warlords
Prices vary from 124 each up to 165 each from auto stores.
Ebay you can get a PAIR for about the same price. No, no need to re-grease. But if you remove them, you will need to clean the rust etc off before re-fitting
07-11-2008, 01:12 PM | #10 | ||
Critical Thinker
thanks James. Thats an extra cost I dont need right now. So I think Im just gonna clean up the unit I have now and worry about it if I need to.
07-11-2008, 03:16 PM | #11 | ||
If your changing bearings you need a 36mm socket
They can be knocked apart and cleaned and regreased but not really worth it for the average bloke, just buy new ones Undo all the slide pins, clean pins/holes and rubbers and regrease and reassemble in different positions, wear in these pins makes the pads wear crooked so swap them around. Caliper Oil is very good as grease tends to go hard, I use this every pad change on the slide and the pistons. Clean ABS sensor while your there, just get the gunk of everything you can see read a few handbrake threads so you know how to adjust it back up, it is a bit tricky Brake fluid flush won't hurt if you have never done it |
07-11-2008, 03:36 PM | #12 | |||
Critical Thinker
The handbrake will be something that will be a bit of a suck to do so I reckon some more research on that area will be needed. Thanks for the handy tips
07-11-2008, 06:17 PM | #13 | ||
Next upgraded Mk1 Leopard
I have to do mine as well. Can youtake some pics when you do yours?
Uncle Ken
07-11-2008, 06:40 PM | #14 | |||
07-11-2008, 07:08 PM | #15 | ||
Critical Thinker
I'll take pics anyway of my mods UK.
Thanks for the referral JC, will check it out.
07-11-2008, 07:10 PM | #16 | |||
JC correct as always.. http://www.fordforums.com.au/vbporta...article&id=319 How goes the non AU?
07-11-2008, 07:32 PM | #17 | ||
Critical Thinker
Thanks for the link. Thats awesome UK. Cheers
07-11-2008, 08:38 PM | #18 | ||
Formerly MR BAXR6t
Mines all fitted on nicely. Alot better than my old stockers!
Current car 94 ED Fairmont 5L in Burgundy Fords ive owned- 2010 FG XR6 5 speed auto in Mystic 81 XD S-Pac 302c 4sp manual 78 Yellow TE Cortina Wagon 4.1L 92 Green EB Fairmont GT replica 01 Black AU XR8 II Manual 04 Rapid BAII XR6T 220rwkw 04 Mandarin BA XR6T 247rwkw 07 BF II XR6T 385rwkw 1980 ZJ Fairlane 302c |
07-11-2008, 08:58 PM | #19 | |||
Which non-AU? The Explorer is great - getting more off-road ready every week, and the NF gets me to work and back each day on LPG; not much more I can ask from it, really. Do I miss AUs? Of course. But my next car may be a BA XR6T - a mate's comes off lease in 12 months, and I can get it for $14k; it has 296rwkw, so if I have the cash, I get the car. A BA is just an AU4 anyway!
07-11-2008, 10:48 PM | #20 | |||
If you get the BA you could then start you next project, BA into an AU : UK
08-11-2008, 01:09 AM | #21 | ||
Walking with God
Great to see you around JC, and as usual you're adding value to the site.
GK
