Old 05-11-2008, 07:52 AM   #1
AC
Saving for a Jet Car
AC's Avatar
Default Fairmont oil pressure gauge too high?
The mrs took the AU off to her mums yesterday(Sydney-Mudgee), she rang me up because the needle on the oil pressure was showing up into the RED, not the whole time. But was quite regularly high up or into the red part. All the manual says, is be concerned if it goes too low or down completely.
I usually only remember seeing around 3/4's when i drive the AU.
Those who know the roads, Sydney to Mudgee will know that its quite diverse driving, lots of huge hills/mountains to high speed zones to drive in, so i can understand the needle moving up and down with the drive.
I just dont know if we should be concerned or not?
For those unfamiliar, here's a pic i stole off ebay :P
Top Left gauge.
RIDES
2011 SZ Territory Titanium TDCi - Smoke
2001 Mitsubishi "BONSAI" GSR Mirage - see thread
AC is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2008, 09:25 AM   #2
guzzis3
AU3 ute EL futura
guzzis3's Avatar
My NF goes high all the time. Could be a stuck pressure relief valve, more likely a dodgy sensor.
I only worry when it goes low...
guzzis3 is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2008, 09:49 AM   #3
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
Mine was doing it for about 12 months. If I gave it some very spirited driving the needle would shoot up to the red and even past it. Most of the time it would sit just below the red. Now it sits on 3/4 and seems perfect again. Could be a dodgy sensor, a bad earth on the sensor is a common cause to apparantly (I belive it earths through the block or something). As long as its pointing somewhat in the right direction I have never worried about it. If it goes low thats when you worry.
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 05-11-2008, 12:09 PM   #4
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice.
There was a ford fix for it, to put a piece of 5mm wire from battery to alternator bracket top nut, but that stops the low oil pressure readings not the high.
Mine goes off the end of the gauge sometimes, just dont worry about it
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
