Old 19-08-2008, 10:49 PM   #1
XR6Stu
Default Rattling doors
Hi guys, ive got an issue that is starting to drive me crazy. All 4 of my doors have been rattling like hell lately when I go over the slightest of bumps. Being a panel beater by trade, Ive been over many many different thoughts and theories on this, and nothing seems to want to fix it, including a new full set of door and turret rubbers. Any ideas and thought and massively appreciated. Thanks in advance.
XR6Stu is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2008, 11:02 PM   #2
ratman
krunch krunch hsv 4 lunch
ratman's Avatar
Are these rattles the doors clanging away or the seals rubbing away on each other?
My XR8 use to do the same thing - seals creaking etc which meant there was a slight movement in the doors. I sprayed an old rag with silicon spray and wiped down both sides to the door sills and the silence is golden.
ratman is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2008, 11:54 PM   #3
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Open the doors and lift them up from the ends, see if thats the noise
If you can feel movement, the hinge pins are stuffed, no fix, need new ones
there is a plastic piece in the middle that wears out.
Assuming all hinge bolts are tight naturally, they can come loose also.
This happens to my taxis regularly
Another option is to realign the door catch on the B pillar to hold the door tighter, just loosen torx and move or hit it in the required direction, this will work for a while only but
Jastel is online now   Reply With Quote Multi-Quote with this Post
Old 21-08-2008, 09:04 AM   #4
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Jastel and ratman speak the truth
i had an awful rattle from the drivers door
until i realised that all three torx screws were loose on the door catch
so i tightened them up
and hey presto! silence!
just remember, duct tape is silver, silence is golden.
Old 21-08-2008, 10:16 AM   #5
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
So why do Olympic Gold Medalists carry on so much?
As for the door info... i'll be using that myself when it comes to re-fixing the doors...
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2008, 12:53 PM   #6
Dezza
Parts bin special
Dezza's Avatar
My driver's door was rattling like mad so I pulled the door trim off and found a completely rusted ratchet sitting in the bottom of the door!
Weekender 1964 US Falcon Futura convertible - Rangoon Red
260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels
https://fordforums.com.au/showthread.php?t=11470868
Daily 2014 SZII Territory diesel - basic runabout
Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more
2000 AUII Fairmont - XR wheels, Ghia interior
2010 FG XR50T ute - XR8 bonnet, Streetfighter intake
Dezza is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2008, 01:13 PM   #7
Nostalgia
LOW AND SLOW
Nostalgia's Avatar
ratman has the right idea. My AU had this same problem and i sprayed the seals with silicon spray and it worked a treat.
Also as Mr Hardware mentioned, check the torx bolts on the driver's side door catch. Mine were all loose also.
Adam.
"Any Color You Like As Long As It's Black, Matt Black, With Flames, And A Bit Of Pinstriping".
Nostalgia is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2008, 05:54 PM   #8
XR6Stu
Checked all of the above, all are good. Its the doors themselves that rattle on thel ocks. They are adjusted right in, and at the moment, the door catch is right up holding the weight of the door, and it still has the rattles.
