02-07-2005, 07:12 PM | #1 | ||
Walking with God
I love the look of the XR6 dash over the standard Futura one.
Anyone made the switch? How hard would it be? A do it yourself job or off to the ripoff dept at Ford? Any idea on cost? Potential snags? Cheers Last edited by GK; 02-07-2005 at 07:23 PM. |
03-07-2005, 10:24 AM | #2 | ||
TL40 Wagon?
Its harder than you think.
But it can be done : ) The AUI and AUII have different connectors and wiring and so on but this can be patched up and the basic sensors will all work. I did it with my Fairmont dash by just using the XR6 backing panel which worked a treat but the speedo reads fast! 220=240 now of course. |
03-07-2005, 05:37 PM | #3 | |||
Walking with God
Cheers. |
03-07-2005, 05:48 PM | #4 | ||
It is because the High spec dash's go up to 240km/h, where as the low spec one's only go up to 220km/h.
I have gone from a low series one to a XR dash. My local mechanic/friend, made up his own wiring loom, and hooked it all up. Works perfectly, and it looks and feels much sportier, with the extra guages as well.
AUIII Falcon Forte, with SIX Appeal |
03-07-2005, 05:54 PM | #5 | |||
Walking with God
You have a good mate there! Hang on to him!I bet it looks a treat too. How long did it take to do? How much did the dash cost you? Where did you get it? Have you noticed any speedo issues eg, too fast or slow? Cheers |
03-07-2005, 06:08 PM | #6 | ||||
It was definately worth it. I have some information/data about the pin outs about it... But here are the basic changes that need to be made, to the plug, to accomodate to the XR6 dash. Quote:
- Oil Pressure Sender - Windscreen Washer Sensor The dash will still work without changing/adding those things. Except the oil will just register has either an on or off type state. This is because there is a Oil Pressure Switch there. I found that my AUIII already had a Sender there stock, so my guess is that AUII + even stock fortes/futuras got the sender. Heres some more information: http://www.fordmods.com/forums/documents.php?doc=4
03-07-2005, 07:29 PM | #7 | ||
Oh Yeah!
Dam I just dropped my dash today and now think I need a new one. I thought when you stuck in a new AU dash it reset the km's to what you had on your car. If not that is a big expensive issue :( Things are not looking good.
Oh no! Duffman can't breath! Oh, yeah! |
03-07-2005, 08:50 PM | #8 | ||
Remember the ~$250 including a new lcd and some other little things.
The kms are kept within the eprom, within the cluster, it is not part of the ECU or the BEM of the car. You may be able to just change over your eprom from your existing dash to your new dash, but i'm not too sure how to do that. Voodoo, just put in a brand new one, and re-programmed it. My guess would be about $100 for that.
03-07-2005, 11:35 PM | #9 | ||
Walking with God
LG,
That is excellent info you've provided. I copied it to a word document for storage for reference later on if needed. The link you provided was also excellent. Many thanks. George |
04-07-2005, 09:42 AM | #10 | ||
Oh Yeah!
Thanks LG that info is great.
My brother actually works for ford so I should be able to get a new dash cheap. He said he could probably get my fixed under warranty but now im thinking the xr6 dash is the way to go anyway. I checked on the parts database and found; TAU2 10849 A INSTRUMENT CLUSTER, XR, LESS POLICE PACK $431.00 TAU2 10849 B INSTRUMENT CLUSTER, XR, WITH POLICE PACK $435.00 TAU2 10849 F INSTRUMENT CLUSTER, (TE50 OR TS50 OR TL50) $589.00 Now im wondering is the police pack the exact same but just with the 2km increases and the ability to alter the speedo to suit larger wheels? Im wondering though if the backing on the dash will be a different colour on the police one or is there any features you lose by having the cop dash. Also is it harder to wire in? For the $4 police sounds the way to go. The te50 im wondering what extra it has for all that money? I doubt id get one as its getting too expensive unless it has an awsome feature the xr one is missing. Also on the fordmods page im assuming wiring for an au1 cluster is the exact same as a au2/3 ?
04-07-2005, 10:10 AM | #11 | ||
not here much anymore
AU1 wiring varies from AU2. AU2 has a lot more to it from what i know, so instructions for AU1 clusters wont be of much use to you.
Police Pack XR dashes just have digital speedo as the difference from normal XR dashes I think, anybody confirm this? T Series dashes are white faced and I think they may also have the gear indicator for the paddle shift in the LCD screen.
2024 F150 XLT
04-07-2005, 11:40 AM | #12 | ||
Oh Yeah!
When you mean a digital speedo how does that work? I mean so there is no needle anymore just a digital readout?
I just read the ford mods article 'AUII/III series have entirely different wiring when compared to the AUI Models' So do you think the mod would still be possible/feasible?
04-07-2005, 06:13 PM | #13 | ||
b2tf, is right, AU1 dashs are different to AU2/3. Better to get a AUII/III XR Dash, but will be even harder probably to wire into an AUI.
As far as i know. The difference between the XR police dashes are that they have 2km/h increments. And they are black, with no Tickford Wings on the backing (According to JC's XR8). T-Series 1, had a White Dash backing with Blue Globes behind it, with the Tickford wings. The XR 2/3, we're blue, and had the Tickford wings on it. The XR dash's also tell you what gear you are in. Whereas the standard falcon/futura ones do not. Fairmont/Fairlane, were like the XR Cop ones, except didn't have the 2km/h increments. Cheers
05-07-2005, 12:06 PM | #14 | ||
pics, pics and more pics plzzzzzzzzz
05-07-2005, 06:37 PM | #15 | |||
Barra Turbo > V8
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+ -2022 Hyundai Tucson Highlander Diesel N Line |
